Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 08-20-2012, 11:36 AM   #151
Scottshotrods
Re: CPP Drop Spindle Special
Originally Posted by joesscamaro View Post
Can I get a price for 2 1/2" drop spindles, 6 lug rotors (HD), and the hardware to mount...ie- bearings, castle nuts, and all that other little stuff. Also, the outer tie rod ends and adapter sleeves to make this work. I believe that is all. Thanks!
P/m sent
Justin
Scottshotrods is offline   Reply With Quote
Old 08-27-2012, 06:16 AM   #152
Bazooka
Keepin it old school
Bazooka's Avatar
price for drop spindles for 63 c10 shipped to 93612? Thanks a lot
Bazooka is offline   Reply With Quote
Old 08-27-2012, 10:38 AM   #153
Scottshotrods
p/m sent
Justin
Old 08-29-2012, 03:41 AM   #154
old cruiser
old cruiser's Avatar
Do you ship to Australia ?
If so price on 2 1/2" drop spindles
Discs , calipers , hoses , bearings etc
to suit 64 c10 with air bags if that makes any difference,
Cheers Matt
old cruiser is offline   Reply With Quote
Old 08-29-2012, 04:22 AM   #155
old cruiser
Cheers Matt
Thats 6 lug discs, forgot to mention that
Old 08-29-2012, 04:58 PM   #156
Scottshotrods
p/m sent
Justin
Old 08-29-2012, 06:21 PM   #157
joesscamaro
Just got my parts from Justin yesterday! There was a slight miscommunication on some of the parts that I received, but Justin was very quick to get things straight and make sure the right parts are on there way. No one is perfect, but customer service goes a very long way, and they have great customer service. Highly recommend these guys! Hopefully see you in Charlotte to take you up on that little deal we made. Thanks again!
joesscamaro is offline   Reply With Quote
Old 09-08-2012, 02:36 PM   #158
Scottshotrods
Thanks for all orders on Cpp parts
Justin
Old 09-09-2012, 03:37 AM   #159
Boosted1984Silverado
Need a price on 2.5 inch drop spindles for 1" rotors on a 1984 1/2 silverado 5 lug. Thanks.
Boosted1984Silverado is offline   Reply With Quote
Old 09-10-2012, 11:36 AM   #160
Scottshotrods
P/m sent
Justin
Old 09-12-2012, 10:27 AM   #161
Scottshotrods
ttt
Old 09-22-2012, 04:09 PM   #162
Scottshotrods
More and more parts of Cpp shipping daily thanks to all the orderes
Justin
Old 10-31-2012, 02:41 PM   #163
Clyde65
Clyde65's Avatar
Im looking at drop spindles. I have a 71/72 front suspension on my 65 now. I really dont want to grind on my powder coated a-arms so would a modular spindle do me better than the traditional spindle? also would stock brakes work with the modular or would i have to go with something else? last question, would I still be able to use my 15" X 8" ralleys?
Thanks Justin,
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-31-2012, 05:23 PM   #164
jephs422
Clyde65-
You'll want to go with the Old school/New school spindle. With the Modular spindle you'll need to run a 13" brake. Without the modular spindle, you can run your stock brakes. I'm sending a PM with pricing now..
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 10-31-2012, 09:39 PM   #165
fishingjred73
fishingjred73's Avatar
I thought you had the option of stock or bigger brakes with the modular, and stock only with the old school/ new school.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 11-01-2012, 03:15 AM   #166
Slow Build
Slow Build's Avatar
Originally Posted by jephs422 View Post
Clyde65-
That's the first time I've heard of that. I thought you had a choice.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-01-2012, 08:17 AM   #167
Clyde65
Clyde65's Avatar
Will I have to trim my a-arms? I currently have 1.5" drop springs
Old 11-01-2012, 06:40 PM   #168
jephs422
I will verify that, but from what I know, you'll need to run the bigger brakes. Let me double check.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 11-01-2012, 06:42 PM   #169
jephs422
Just double checked with Justin and he reiterated that the Modular spindle is only designed to be run with the bigger brakes. It makes sense because the caliper bracket is the 2 bolt set up.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 11-01-2012, 06:51 PM   #170
62-One-Ton
62-One-Ton's Avatar
Price on 73-87 drop spindles with 1.25" rotors. And some 6 lug rotors. shipped to 95682. Thanks.
62-One-Ton is offline   Reply With Quote
Old 11-01-2012, 07:35 PM   #171
fishingjred73
This is what's throwing me. This is off CPP's web site
Modular™ Drop Spindle Complete Front Brake Kit
Looking for a spindle and brake kit for your lowered truck with big tires and wheels? We have it! Introducing CPP's new modular 2" drop spindle and drop spindle wheel kits for 1960-87 Chevy pickups. Our exclusive new design helps solves tire to fender interference commonly found with lowered trucks. Our new modular spindle and bracket works with factory 1971-87 C10 brake components, or for a HIGH performance option, combine our spindle with the NEW CPP 13" Rotor
James
Member of
Old 11-01-2012, 10:36 PM   #172
Slow Build
Slow Build's Avatar
I've been wanting Modular Spindles since they were introduced. Now I'm hearing all these ifs, ands or buts (do they really not widen the stance more than 5/16" per side, you can't run dust shields and now you need to buy larger brakes). I'm getting more confused the more I here about them.
Here is a copy of a PM that I sent to CPPJEFF in Feb. 2010.
Hi Jeff
I'm interested in the modular spindles for my 64 C-10. Do I need to also buy the brake brackets to use the stock 12" rotors and calipers? I'm going to be needing a few other items also, list not complete yet, are you offering any discounts?
Rich
Rich my first name is DISCOUNTS!! LMAO!! Yes you will still need the brackets with the 12" stuff and they are free with a purchase of spindles. Get a list together and i will help you out. Thanks
Past GM Trucks:
Old 11-02-2012, 11:27 AM   #173
jephs422
If there is a bracket that will allow you to run the stock brakes, I have never seen it. That doesn't mean that it doesn't exist, it just means that I need to call and find out exactly what the deal is. Unfortunately, everyone who knows anything is at SEMA right now. I'll have an answer Monday.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 11-02-2012, 12:08 PM   #174
fishingjred73
These should be the parts # that would allow you to run stock brakes.
CP301062 1963-70 C10 Drop Spindles
6087DBK Bracket kit to work with factory disc brakes and CPP Modular Spindles
James
Member of
Old 11-02-2012, 05:22 PM   #175
jephs422
Correct. I just got the same information, and if it's mentioned when the spindle is ordered, the bracket is free of charge.
Also, the track width does not change on 63-72 with the upgraded brake conversion, and it's also not changed on the 73-87 with stock brakes.
63-72 with stock brakes will push the track out 5/16 per side.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
