11-09-2003, 03:51 PM | #1 |
looking for front roll pan
Looking for a front roll pan...perferrably fiberglass..metal if thats all i can get...for a 67
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
11-09-2003, 05:49 PM | #2 |
Tim Christian has them,however you do know that you will have't cut several inches off the frame horns to make it work,just something to think about.
Things happen for a reason! |
11-09-2003, 05:59 PM | #3 |
That was one of the plusses for me....im trying to get it as light up front as I can...thanks..Ill look up Tim
11-09-2003, 06:40 PM | #4 |
Project56 on hold
on a front pan, the weight differential for the metal vs fiber will not be significant enough to worry about. the fiber has to be reinforced too much to avoid flex and ends up adding weight.
mar-k makes very nice front pans......http://catalog.mar-k.com/
Shamrock Customs Forever-in-the-Future Custom Shop 2009 Mitsubishi Lancer GTS daily driver 1956 Chevy Stepside rodstoration on winter hold |
11-09-2003, 07:10 PM | #5 |
theres on eon e-bay ( not mine) now for 80 bucks. Good Luck
11-10-2003, 09:36 AM | #6 |
67-72 Addict!
Looks great and less weight!, I like it.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
