#76 |
Re: Crusty Rusty Leaky Squeaky 67 Step
That hood looks like it is in pretty decent shape, nothing wrong with it that a polycarbide disk cant fix
![]() I like the new engine parts, combined with the Vortec heads they should really breathe some life into that old small block. You mentioned something about flat top pistons, did you get those ordered yet? I think you are going to kick my ass in a straight line but I'm gonna have you in the corners, so in the interest of making it fair we have to race on a european style roadway, I think old K4 will do nicely. ![]() |
#77 | |
![]() ![]() ![]() ![]() Thats hilarious! forced air induction quick connect coupling ![]() Nice sheet metal work on the speaker enclosures. Do you have a press brake too? Must also have a shrinker or ? english wheel for that curved flange on the repair piece? Impressive!
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#78 |
![]() Join Date: Mar 2012
Thanks, Dan! I have a 4' box and pan (finger) brake and a small press brake for those tough-to-get-at bends. And, yes, a shrinker, stretcher and planishing hammer. However, I don't have the floor space to dedicate to an English wheel, so when I need to roll out a curved panel, I have a buddy with three of them in his shop.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
#79 |
I have to get over there for a shrinker lesson. Been wanting to get into that end of it. Parts look great! I had the blaster do the edges and supports, and stripped the rest with the 80 pad. Good stuff, can't wait for the next stage!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#80 | |
#81 | ||
#82 |
Made some more progress on the door bottoms. Welded in the corner patch then dressed all the crappy looking welds. I know I'll get the hang of the MIG, but it's starting out as a love-hate relationship. Spotwelded the speaker box in place and did some final trimming and fitting. Media blasting turned up some minor areas of rust that I need to patch before welding the door bottom on permanently. Bondo is also covering a dented area someone fixed the old fashioned way ...by drilling holes thru the skin and using a slide hammer with a sheetmetal screw on the end to yank the dent. All the pookey will have to come out so I can weld the holes up. Having the door bottom removed gives me better access for the necessary hammer and dolly work. When the door bottom goes on the final time, I'll dolly down the flanges I left on the corner patch which should give me a nice repair.
Xeen gave me a much appreciated heads up and some good suggestions on insulating the speaker enclosures. I've never done a stereo system that consisted of anything more than four speakers and an in-dash radio. Lots to learn ...hope it doesn't end up being an "old dog, new tricks" deal.
#83 |
Vic I hope that hood works out for you. I am glad you can use it because I don't want to store it for the 5 years my project will take. I am also bummed I couldn't stop by Friday. I had to play clean up at work so I was sending emails and making calls all afternoon.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
#84 | |
#85 |
Vic, you do awesome metal work. You definitely inspire me to become better at it.
Scott |
#86 |
Thanks, Scott, all you need is practice and more practice. Once heard that the only difference between guys like us and someone like the late Boyd Coddington is that his scrap pile is bigger.
#87 |
Exciting build. I know the feeling...great work!
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#88 |
Metal work looks great! MIG tip: I wound up aiming at the leading edge of the previous tack, instead of side by side. Got less light thru after that way. Tell me to shaddup, you prolly know this, just kickin in my .02. Looks great, as always!
#89 | |
Weld spatter already burned a hole thru my jeans. ![]()
#90 |
Well, if I can impart- Get online and get the .023 easygrind from ESAB. Lots easier to work with, and a Lot softer bead. Your fitup looks terrific. Wire About 1/8 or so out of the shield. Pretty good "pop" on the gas, this all happens in a hurry. Speed at whatever works best, you'll know fast. I tended to go vertical with a 10deg or so tip toward the previous tack. I always got taught to push unless there was no other way. I also had several starts 2-3 inches apart. I dont run a bead on sheet. LOTS of heat that way. I just run tacks over tacks, but I actually kick the heat up a bit for a fast bite, kinda like "flooring" the tig pedal. Here's my pattern-
x----------------x--------------x--------------x---------------x---------------x then- x-------x--------x-------x--------x--------x----x-------x------x--------x------x then- xx------x--------xx------x--------xx-------x-----xx-----x------xx-------x-----xx then xxx-----x--------xxx------x------xxx-------x-----xxx------x-----xxx------x---xxx and so forth, till your gaps are filled in. Clear you calendar, open a beer, and settle in. Kinda like painting a car. Make a round, go sip you beer. Don't do more, don't poke at it, don't screw with it, don't get horny and just weld 'er up. It actually goes faster than it would seem. Why am I telling you this? You've forgotten more than I'll ever know.
#91 |
I don't see why you can't use compressed air to cool the metal so you can work faster, but then I'm not a welder so what do I know about it.
#92 |
Well, you can, and lotsa folks do, but you run the risk of shrinkage, even more than you're gonna see. It's a good management tool though, used properly. I just prefer to go slow. I'm no ones expert on anything, believe it!
#93 |
I'm glad you're telling me this because I'm new to MIG and can really use the advice. Thanks!!
#94 |
67cheby
![]() Join Date: Sep 2008
that is some impressive metal work on that door
#95 |
Thanks! I've seen your build thread and I'll be thrilled if mine turns out even half as nice as your ride.
#96 |
After spending the last week or so on the CAD program and cranking out some parts for friends on the lathe and the mill, I'm finally back on CRLS. I needed to clean up the inside of the doors so the acoustic sheet would adhere to the surface. After I got the doors back from the blaster, there was still a lot of the original factory asphalt based material on the inner surface of the skin. Blast media won't really touch that stuff, so out came the scraper. Some of the gunk chipped off readily, but most was stuck pretty tight. I quickly tired of using a putty knife and hammer, so while my better half was out running errands, I asked her to stop by HF and pick up a pneumatic scraper. Turned out to be the best 20 bucks I've ever dropped there. I generally have low expectations for their tools, but this one is a solid piece. Took me longer to scrounge up an air fitting and install it than it did to remove the rest of the door crud.
After scraping and wiping down the surface, I cut the Rattle Trap to length and started laying it in. It conforms pretty well with the shop at 70 degrees and it didn't take long to cover the entire inner door surface. I always cover the seams with aluminum Shurtape because when the acoustic material gets warm, it will "bleed" droplets of the black asphaltic material. Covering it with aluminum tape seals the seams and edges and locks in the pookey. I mocked up the door bottom again and drilled a hole thru the door jamb and one in the speaker box for routing the speaker wires when the time comes. I cut a length of 1/2" thin wall chromoly tubing to run between the jamb and the speaker box. I'll weld the tube into the door jamb and then seal around the other end in the speaker box. Since the tube runs downhill, there should be no way for moisture to enter the enclosure. Now I just have to repeat the process on the driver side door.
#97 |
Looking good. I am in the process of dissecting my donor roof. I might need to take you up on that spot welder soon. Are you going to be working on the truck tomorrow? If so I might swing by and say hi.
#98 |
Work looks great!
#99 |
Yep, I'll be here all day. Drop by anytime. Shop is sort of a mess. Had to rearrange everything to make a spot for Silver.
#100 |
Is the Auction this weekend or next? Good luck either way!
