Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-14-2010, 08:30 AM   #1
airbornewally
airbornewally's Avatar
fuel sending unit / fuel gauge mystery
OK, so I've recently inherited a 1972 C10. My father-in-law has used a stick for as long as I can remember to measure the amount of fuel in the tank. I have read many threads regarding this problem (not necessarily using a stick, lol), but haven't really been able to find a solution yet. With the sending unit installed in the gas tank, and the wire attached to the sending unit the gas gauge reads 'empty'. If I remove the wire, the gas gauge spikes past 'full'. However, if I remove the sending unit from the gas tank, attach the wire and ground the unit, the gas gauge works! I have ohmed out the sending unit. I know it's supposed to read between 0-90 ohms, respectively representing empty thru full. The reading I got on the sending unit was closer to 15-105 ohms. I have made sure that there are no cracks or pinholes in the float. It just seems to not work when the darn thing is installed in the gas tank! I know I must be missing something. If anyone has any ideas, I would be greatly appreciative.
______________________
Matt
1972 Chevy C10
V8, 350
airbornewally is offline   Reply With Quote
Old 07-14-2010, 08:58 AM   #2
cdowns
cdowns's Avatar
Re: fuel sending unit / fuel gauge mystery
have you tried running a good ground wire directly from the sending ynit to the body of your cab?
Old 07-14-2010, 11:45 AM   #3
fixit-p
fixit-p's Avatar
You've done all the tests now you just need to interpret your results. I see 2 possibilities 1, your float is stuck (down when in tank) or 2, when installed in tank your sender wire is shorted to ground (check the insulator or if terminal is making contact with tank). When the sender is installed in the tank is the empty reading on the gauge (float down) the same as when you tested it out of tank and grounded? If the reading on the gauge out of the tank was slightly higher than when it was installed it would point to possibility #2 above.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-14-2010, 11:51 PM   #4
airbornewally
I will definitely check out the insulation on that sending unit wire and update if I get any new results, thanks!
Matt
1972 Chevy C10
V8, 350
Old 06-19-2013, 11:20 PM   #5
cheguevara
Did you get the sending unit fixed? Was it the ground wire?..I got the same issue
cheguevara is offline   Reply With Quote
1972 fuel gauge, fuel gauge, fuel gauge & sending unit, fuel sending unit
