Old 06-13-2013, 06:55 PM   #1
jsbgump
Gone Fishing
jsbgump's Avatar
a/c issues
I have a 2006 gmc sierra crew cab and the ac will blow cold on the pass and hot on the driver side. the problem is intermittent right now. I changed out the blower motor resistor module last year because it quit blowing air at all with some of the same hot/cold issues. Any ideas or should I just go get it checked out?
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-22-2013, 06:54 AM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: a/c issues
Any ideas?
Build Thread
Old 06-22-2013, 08:56 AM   #3
truckdude239
truckdude239's Avatar
Re: a/c issues
you got the gm blend door problem
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-10-2013, 10:39 PM   #4
mr_earnhardt1
Re: a/c issues
I own 5 of these trucks, and every one of them has had this issue at one time or another. What i've found that works most every time, is to simply turn the truck off, unplug the module in the dash, and plug it back in. I've also had it where I've just shut the truck off, started it back up and problem gone. Now this is not a cure, but it works and since it only seems to happen once in a great while so I haven't looked into it further. Best of all, it's free!
Hope this helps!
mr_earnhardt1 is offline   Reply With Quote
