Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-01-2013, 11:50 PM   #76
Captainfab
60-66 Nut
Re: '60-'62 POwer Brake Booster Adapter Bracket With A Clutch
I'll send you an email
Originally Posted by watsontyson View Post
let's try this again with spell check lol watsontyson@hotmail.com
Old 09-10-2013, 11:11 AM   #77
clemdaddy
clemdaddy's Avatar
you're right... that is exactly what i need.
not sure what the difference is in the 2 setups you offer. pm me if you wish...
thanks, clem
clemdaddy is offline   Reply With Quote
Old 09-10-2013, 11:52 PM   #78
Captainfab
60-66 Nut
I'll send you a PM Clem.....
thanks, clem
Old 09-26-2013, 02:06 PM   #79
burbluv
burbluv's Avatar
Hey Captain,
I have the 62 4wd suburban with the 350 and original 4 on the floor. I am looking to get my drum brakes to work well enough that I can pull an Airstream sometime in the future. I was told by classic performance that this is the booster setup I will need especially since I have the dual reservoir for the hydraulic clutch.
http://www.classicperform.com/Store2.../MT6062BBD.htm
Can you confirm? And if that is what I am looking for is this the adaptor kit that I need to get from you?
Thanks,
AJ
burbluv is offline   Reply With Quote
Old 09-26-2013, 10:48 PM   #80
Captainfab
60-66 Nut
That is what CPP came up with to compete with the conversion I make that I am selling in this thread.
Old 09-26-2013, 10:50 PM   #81
burbluv
burbluv's Avatar
Oh sorry. I thought it still needed the bracket. Thanks
Old 09-26-2013, 11:24 PM   #82
Captainfab
60-66 Nut
Mine is a direct bolt up to the firewall using existing holes, I do not think theirs is. Typically with CPP's power brake booster conversions, you have to drill the mounting holes in your firewall.
Old 10-17-2013, 08:17 PM   #83
jmguy
hi everyone
have used the captians brackets for my 62 GMC with fliud clutch
and am using a 1987 S10 booster
can anyone tell me if a round brake master cylinder unit from 66 chevy truck will fit on my booster please
it would look a little more original than the crappy S10 and I have no idea how to make the dual set up on the S10 unit work on my one line brake system
comments most welcome thanks
jmguy is offline   Reply With Quote
Old 10-17-2013, 10:45 PM   #84
Captainfab
60-66 Nut
To use your original '66 master cylinder, you will have to change the intermediate pushrod to the long one.
I would recommend upgrading to a dual reservior master cylinder. There is a write up in the '60-'66 FAQ index on how to do it. Then all you will need is a master cylinder for a '70 Buick Estate wagon, which will work with the short intermediate pushrod. Of course this is assuming you still have 4 wheel drum brakes. If you have discs up front, you really should not use the original master cylinder, and you will need a master cylinder and prop valve for a disc/drum braking system.
You do not have to use the S10 master cylinder with the S10 booster. There are many other master cylinders that will work.
Originally Posted by jmguy View Post
hi everyone
Old 12-06-2013, 02:16 AM   #85
Captainfab
60-66 Nut
Here is a list of the confirmed compatable boosters.
http://www.67-72chevytrucks.com/vboa...&postcount=183
Of course don't forget about the hydroboost.
Old 12-10-2013, 02:35 PM   #86
60ShortStepGMC
60ShortStepGMC's Avatar
My application is a 60 gmc w/hydraulic clutch, drum/drum. Christmas is near so I'm making a list and checking it twice.
I like your "option 2" but saw some changes in subsequent posts. Just checking the price and product: they remain as you mentioned them in post 43 (199.50 + 15.00 shipping 7.50 powder coat option) and 44 (new linkage)?
<newbie section>
Many places say no proportioning valve required for drum/drum applications, but one would be required because of the new dual diaphragm master cylinder, correct? And no doubt I should replumb all my lines as part of this upgrade?
Generally the improvement gained by this change to my stock truck is power assisted braking and an independent three-line setup (front brakes, rear brakes, clutch)?
</newbie section>
60ShortStepGMC is offline   Reply With Quote
Old 12-10-2013, 08:00 PM   #87
60ShortStepGMC
To answer my own question: No, a proportioning valve is not required for a drum/drum application with dual diaphlegm master cylinder. This thread helped clue me in:
http://67-72chevytrucks.com/vboard/s...=332148&page=4
Old 12-11-2013, 01:46 AM   #88
Captainfab
60-66 Nut
You are close on the price. The bracket with the Wilwood clutch master and linkage is $199.50, the shipping is $15.76, and the satin black powder coating is $7.50, for a total of $222.76. I will need to know what clutch master cylinder you are using, so that I can supply you with the correct size clutch master cylinder.
You are correct that you do not need a proportioning valve for a drum/drum brake system. When converting to a dual reservior master cylinder, you do have to replumb at least the front brake lines. You can reuse the line that runs on the backside of the crossmember, for the rear circuit, by using a couple of inverted flare plugs as needed in the tee's.
If you will be keeping the original clutch slave cylinder, you should be able to keep the original line from the slave up to and including the hose at the firewall. Then just run a new line from the new clutch master, down to the hose on the firewall. Of course this is only if the original line and hose are in good useable condition.
<newbie section>
</newbie section>
Old 12-11-2013, 08:52 PM   #89
Weasel235
Great product Captianfab.
Install was quick and painless.
62 GMC LWB Stepside (Project)
95 S-10 350 Conversion
68 Camero
07 Harley Heritage
73 CB 750 Bobber
XS 650 Bobber
Weasel235 is offline   Reply With Quote
Old 12-12-2013, 12:35 AM   #90
Captainfab
60-66 Nut
Thanks for the compliments
Old 04-20-2014, 10:39 PM   #91
60ShortStepGMC
Nice product CaptainFab!
Old 04-21-2014, 01:38 AM   #92
Captainfab
60-66 Nut
Old 08-01-2014, 05:17 PM   #93
J Williams
J Williams's Avatar
Okay Captainfab, I had talked to you earlier about my 63 C10 NV3500 conversion. So I am ready to get this underway. You show the 60-62 C10 with the vacuum booster and clutch mc bracket along with the Wilwood MC and all needed hardware for 199$ Will this be the same price for the 63 C10? Let me know a price and how you want paid.
Thanks again for your R&D
63 C10
J Williams is offline   Reply With Quote
Old 08-01-2014, 05:24 PM   #94
J Williams
J Williams's Avatar
Also I would like to add power steering. Could you give me a package deal with the power steering mounting plate as well? Thanks again
63 C10
Old 08-02-2014, 12:08 AM   #95
Captainfab
60-66 Nut
I replied to your PM
Old 10-07-2014, 07:55 PM   #96
Peneffer
Just sent you a quick message. Can't wait.
Peneffer is offline   Reply With Quote
Old 10-07-2014, 10:27 PM   #97
Captainfab
60-66 Nut
Old 12-04-2014, 07:57 PM   #98
allisrules
Thumbs up Re: '60-'62 POwer Brake Booster Adapter Bracket With A Clutch
I like your idea would like to have the option 2 set up for my 1961. Please advise how I could compliant a transaction with you.
allisrules is offline   Reply With Quote
Old 12-05-2014, 01:21 AM   #99
Captainfab
60-66 Nut
Old 04-07-2015, 01:21 AM   #100
SierraMtns
SierraMtns's Avatar
Originally Posted by Captainfab View Post
Here are a few pics of the re-design of this kit. The new linkage assembly allows full stroke of the pedal, with plently of adjustment to fine tune it to your liking. Also there is more clearance to the wiring plug on the firewall next to the clutch master cylinder.
Do you have any plans on making a kit that will fit a 67?
SierraMtns is offline   Reply With Quote
