Old 10-19-2013, 03:30 AM   #1
isoyoye
isoyoye's Avatar
Disabling Column Shifter
Hi Guys,
Been a Member for a few months and working on my 64, quick question for the respectable knowledge guys out here. i am converting from column to floor shifter and i just realized, can i just disable and remove the column shifter and retain my steering column instead of having to buy a new column. Already got the Ididit one but i sure can return it. Any thoughts and is this ok and doable?
Thanks a bunch
isoyoye is offline   Reply With Quote
Old 10-19-2013, 06:23 AM   #2
brokenspoke
brokenspoke's Avatar
Re: Disabling Column Shifter
Yes....take the arm off and linkage under the hood
brokenspoke is offline   Reply With Quote
Old 10-19-2013, 07:59 AM   #3
isoyoye
isoyoye's Avatar
Thanks BrokenSpoke, i figured but thought i might be missing something. Back goes the Ididit Column. could you suggest or would you know the most appropriate floor Shifter kit for a th400? Maybe with a longer stick than the usual. my reserch on this forum hasnt been very direct
Old 10-19-2013, 09:38 AM   #4
geezer#99
geezer#99's Avatar
Check here.
THey make some nice tall shifters.
http://www.lokar.com/index.html
column shifter, floor shifter, steering column
