Old 10-20-2013, 07:59 PM   #1
bonnieclyde100
power window regulators on the cheap
i have made factory style power window regulators at 1/3 of the price of aftermarket ones. they are over 300 dollars i made mine for less than 100 dollars. here is the link to video
http://www.youtube.com/watch?feature...&v=hG23ms_x74M
bonnieclyde100 is offline   Reply With Quote
Old 10-20-2013, 10:04 PM   #2
mgkgmc
mgkgmc's Avatar
Re: power window regulators on the cheap
Great ingenuity there!
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 10-20-2013, 10:13 PM   #3
mmiddle
mmiddle's Avatar
I watched the vid. and am impressed. What motors did you use?
Great job
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 10-20-2013, 10:53 PM   #4
bonnieclyde100
Great job
i used some motors that are for a 1991 chevy truck and i got them at oriellys
Old 10-21-2013, 10:03 AM   #5
DGulliver
DGulliver's Avatar
Brilliant!
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8
'74 Trans Am 400, '80 Trans Am Indy Pace Car
Mercedes AMG S55, SLK230 Kompressor, GL450
'96 Dodge Indy Ram Official Indy Truck
'99 Porsche 911 Carrera
DGulliver is offline   Reply With Quote
Old 10-21-2013, 08:17 PM   #6
bonnieclyde100
here is the pattern of the motor holder plate maybe you can print it out and use it. when drilling mounting holes i would drill 1/4 hole and one 7/32 hole and tap it and use motor to mark where last hole will be to make sure they line up. the two screw threaded into the plate will need to be ground down on back so the regulator gear wont hit them when rotating.
Old 10-21-2013, 09:07 PM   #7
bonnieclyde100
someone on youtube asked for more of a write up so here it goes
step1 remove the spring carefully
step2 ground down crank rivets and remove it.
step3 ground down the two rivets thet hold the gear to the shaft and
drive them out.
step4 turn the gear down 90 degrees and weld it to the shaft.
step5 trace and cut out motor plate.
step6 cut 1 1/2 hole for motor gear to pass through and drill mounting holes (look at pattern) and test fit motor.
i would the 1/4 inch hole and one of the 7/32 to be tapped and mount
motor to mark the last hole to be drilled and tapped.
Old 10-21-2013, 09:24 PM   #8
bonnieclyde100
step7 time to weld motor plate to regulator mounting plate. look at piture to see how it needs to be placed and welded. put plate in between regulator mounting plate and regulator gear with shim to put a little clearance between gear and motor plate and clamp together to hold while welding. test fit motor to make sure it engauges the gear correctly make adjustments if needed and weld.
step8 ground down welds and paint
step9 assemble and test
this was the driverside passenger side is opposite of driver
Old 10-21-2013, 09:31 PM   #9
mmiddle
mmiddle's Avatar
Wow, You Da Man.
Mark
Jesus is the Way!
Old 10-21-2013, 10:13 PM   #10
hugger6933
I think I got some leftover door parts from that body style truck[88-98] from when I used to build them. If I haven't thrown them all away I will look for some motors tomorrow. I have three trucks to build, it should suit some of them. Are you gonna put the switch in the old crank arm hole? Do you plan on using the old GM style two flat button on the drivers side then the single flat on the pass like would have been there, Or is your int. customized? That is some real good thinking on this how long have you used it? Keep up the good work and the good ideas, that is what this country was founded on and also this hobby that we so dearly love. Jim
hugger6933 is online now   Reply With Quote
Old 10-21-2013, 10:26 PM   #11
jorgensensc
jorgensensc's Avatar
Excellent!!! Thank you!! I have been needing to it owner windows in my suburban but they don't make rear kits. This will work perfectly!!!
Shawn.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-21-2013, 10:30 PM   #12
'68 Short Step
'68 Short Step's Avatar
What an awesome project! This is definitely going on my to do list.
'68 Short Step is offline   Reply With Quote
Old 10-22-2013, 08:19 PM   #13
bonnieclyde100
i have custom door panels and i plan on using the switches that came with the aftermarket power window kit that didnt have enough power to lift the windows with all the new weatherstripping.
Old 10-22-2013, 08:54 PM   #14
hugger6933
How thick is the plate that you bolted the motor to? Does the motor plate just weld to the regulator in that one spot that is pictured? I was just wondering about those two thing as there would be a bit of wobble on the end of the plate if it isn't supported some kind of way, but I didn't build it , It looks great. Thanks for the tips and the help. Jim
Old 10-22-2013, 11:30 PM   #15
bonnieclyde100
the plate is 1/8 inch thick . it is welded in two about 3/4 inch apart one on each side.
Old 10-22-2013, 11:32 PM   #16
jorgensensc
I really like this idea! Thank you for taking the time to write it up. Just curious, had you considered or tried using the regulators off the 90's trucks? I know they won't mount in the same holes, but could they work with spacers maybe in a different spot?
Old 10-23-2013, 02:09 AM   #17
sambudo
sambudo's Avatar
Great video something to add to my to do list. Thanks
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 10-23-2013, 06:12 AM   #18
hugger6933
The 90's truck regulators are like twice the size of the ones that go in the 67-72 trucks. I would doubt that they would even fit inside the doors. Jim
Old 10-23-2013, 06:23 AM   #19
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Thumbs up Re: power window regulators on the cheap
Great work! I often wondered if another GM power window motor couldn't be "retro-fitted" into our trucks for alot less money.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-23-2013, 10:07 AM   #20
Custom 68
Custom 68's Avatar
great, subscribed
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-23-2013, 11:42 AM   #21
AirSpeed
AirSpeed's Avatar
Do you have a model number for those motors?
AirSpeed is offline   Reply With Quote
Old 10-23-2013, 07:43 PM   #22
bonnieclyde100
oriellys part numbers
Part # : 42-131
Part # : 42-130
and alot of time other auto parts stores use same numbers
Old 10-23-2013, 11:14 PM   #23
colgad
colgad's Avatar
Amazon sells the motors for a total of 68.91 for both
Dorman 742-142 Window Lift Motor Dorman 742-142 Window Lift Motor
Sold by Amazon.com LLC
Dorman 742-143 Window Lift Motor Dorman 742-143 Window Lift Motor
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 10-31-2013, 10:59 PM   #24
bonnieclyde100
i drove mine out with a hammer and a nail net. mine came out pretty easy but how ever you have to do it is fine. take some pics when there done
Old 10-31-2013, 11:05 PM   #25
Bigdav160
Bigdav160's Avatar
I bought those PW motors from Rockauto for $15 a piece recently.
I was going to duplicate the drawing in Sketchup but it appears a couple crucial measurements are missing.
I think I have an extra regulator. I'll try to come up with something a little more precise.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
