Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 12-15-2013, 05:25 PM   #251
ryserstine
ryserstine's Avatar
Re: Camaro Caliper Brackets
Sorry disregard plunger that would be an issue if i were to change out the brake booster,and it sounds like thats not needed.Thanks for the help i'll post more pics when completed.
ryserstine is offline   Reply With Quote
Old 12-16-2013, 04:17 AM   #252
ls1nova71
ls1nova71's Avatar
I need a set of these, but don't have time to read through 11 pages to find the price on the powder coated ones. I se a price for bare steel on the first page. I'll send a PM.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-17-2013, 12:27 AM   #253
Captainfab
60-66 Nut
PM replied to
The satin black powder coating is an additional $28.00
Old 12-17-2013, 03:31 AM   #254
ls1nova71
ls1nova71's Avatar
Think I'll go with the unpainted set. Will send PayPal right away. Thanks.
Old 02-06-2014, 10:02 PM   #255
bL.A.zer90045
do you make any brackets to accomadate the 98-02 fbody calipers?
bL.A.zer90045 is offline   Reply With Quote
Old 02-07-2014, 01:06 AM   #256
Captainfab
60-66 Nut
No I do not.
Old 02-07-2014, 02:17 AM   #257
crob35
Will these work with the wilwood d52 calipers?
crob35 is offline   Reply With Quote
Old 02-07-2014, 02:28 AM   #258
Captainfab
60-66 Nut
No, these only work with the '93-'97 F-body calipers. If you want to use the Wilwood D52 calipers, you will need my D52 brackets.
Old 02-07-2014, 03:21 PM   #259
bL.A.zer90045
Originally Posted by Captainfab View Post
No I do not.
ok,just asking as i have 5 sets of them(98-02 disc set-ups,gbody builder)so for the camaro brakets(94-97) with hardware it is 125.00 shipped? i would need them shipped to 87144.thanks!
Old 02-07-2014, 04:24 PM   #260
Captainfab
60-66 Nut
The total for a bare steel set is $121.65. If you wish to have them in satin black powder coat, the total is $139.65.
Old 02-07-2014, 08:43 PM   #261
dan468
dan468's Avatar
Regarding the corvette MC, front reservoir goes to front brakes and rear to rear? Just did my 64 lincoln and it was opposite so I thought I'd ask
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 02-08-2014, 01:41 PM   #262
Captainfab
60-66 Nut
I believe that is correct, but I'll have to verify that. Are the fittings different sizes? I was thinking that the general rule was that on masters that have equal size reserviors, that the front is front brakes and the rear is rear brakes.
Old 02-09-2014, 08:31 PM   #263
dan468
dan468's Avatar
The rear port is the bigger one...
Thank you for making this bracket. It would have been much harder to make this work without it.
Search Keyword: Porterbuilt, dropmember, big block chevy
68 C-10
Build thread
Old 02-13-2014, 08:34 PM   #264
HomoMonkey
Hey CaptFab, want to order a bracket for Impala disc/Camaro caliper. sending paypal now.
HomoMonkey is offline   Reply With Quote
Old 02-14-2014, 12:20 AM   #265
Captainfab
60-66 Nut
Payment received and email sent
Old 08-26-2014, 12:27 PM   #266
snipescastle2
snipescastle2's Avatar
ryserstine,
what is the bracket shown in this picture? or is that some sort of JIG for welding/fabrication? if you don't mind me asking?great work! that bracket caught my eye, just wondering what it's for.....
Ben
snipescastle2 is offline   Reply With Quote
Old 08-26-2014, 11:29 PM   #267
Captainfab
60-66 Nut
If you are talking about the bracket that is below and behind the caliper, that is the panhard bar mount that is on the NASCAR trailing arms.
Old 08-27-2014, 09:29 AM   #268
snipescastle2
Talking Re: Camaro Caliper Brackets
that's a pretty stout looking bracket, I was just wondering what it was for, never seen one of those before.....
Thanks Captainfab!
Ben
Old 01-13-2015, 06:04 PM   #269
weav1
weav1's Avatar
Are you still making these brackets
weav1 is offline   Reply With Quote
Old 01-13-2015, 09:55 PM   #270
Tims71
That bracket is on the end of the trailing arm and where the adjustable track bar mounts
Tims71 is offline   Reply With Quote
Old 01-14-2015, 12:33 AM   #271
Captainfab
60-66 Nut
Yes I still make these as well as all of my other products
Old 01-23-2015, 05:18 PM   #272
Tom
driving is in my blood
Tom's Avatar
Mother of god......I don't know how I've never seen this before with all my years on the board, but I am so glad I finally did!!!! I'm in the middle of a full repaint on my '98 but the rear brakes are next on the list after paint. Thank you for offering these!!!
Old 01-24-2015, 02:02 AM   #273
Captainfab
60-66 Nut
I do not yet make any rear disc brackets for the '88-'98 trucks. I keep hoping to find the time to work on those, but with working 70-80 hrs a week every week, time is scarce. Does your truck have the 8.5" 10 bolt or the 9.5" 14 bolt?
Old 02-03-2015, 02:04 PM   #274
Crash'd Artwerks
What rotors can I use with these brackets and calipers to swap my truck to 4.75 bolt pattern?
I've seen Chevy Astro van rotors mentioned, but the obvious Camaro rotors that match the calipers would be nice to use.
Crash'd Artwerks is offline   Reply With Quote
Old 02-04-2015, 12:18 AM   #275
Captainfab
60-66 Nut
The only rotor that can be used with these brackets without modification are the ones they are designed for.
The '93-'97 F-body rotors have a 5 x 4.65" wheel stud pattern, are smaller in diameter and a different height.
I have started on a different set of brackets for the trucks using the 5 x 4.75" wheel stud pattern, but I don't know when I will have time to finish them up.
