10-14-2013, 11:29 PM | #26 |
Re: Mounting and Plumbing AccuAir Elevel ideas
Here's where i just mounted mine in last 2 pics
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
10-15-2013, 09:28 AM | #27 |
Sweet, Thanks! So I looked at Old Aux yesterday and I'm guessing that the bracket is intended to be used on raised bed floors. Is that correct? You both have them mounted in a similar location below your raised floor.
I'm not sure how you'd mount this under a stock height floor?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
10-15-2013, 11:54 AM | #28 | |
10-16-2013, 08:26 PM | #29 |
I have my tank in a similar spot as dznucks' on the first page, and my compressor, manifold, and wiring mounted on the inside of the frame in front of that. It keeps it fairly tucked up. I have my compressor intake filter in the cab to keep it clean and dry. I can grab a pic next time I'm under the truck if you want, though I must warn, it's not pretty!
'71 GMC pickup; "Ashley," |
10-18-2013, 10:59 AM | #30 |
Thanks guys. I don't have the parts yet. I'm still saving $$$, but it's lower on my priority list so it will be a while. I'm just trying to get some ideas. I may change my mind by the time I actually do my air management install.
Right now I'm leaning toward the PB tank/compressor mounts with dual compressors and 3 gal tanks on either side in front of the rear tires. I'm thinking the best place for the valve and control box will be in the middle somewhere, but I'm not set on that yet. jtp67-72, I love how you dressed up your bed mounts. That's pretty slick.
10-18-2013, 06:34 PM | #31 | |
12-12-2013, 12:09 AM | #32 |
Gofast68c20. Nice Hard line set up. im doing something similar.
12-12-2013, 12:14 AM | #33 |
Superflystieny, that is Sick!!
12-13-2013, 09:27 PM | #34 |
Subscribing as I'm trying to plan out my new build.
Is there any option to mount the tank(s) under the bed of a stepside?
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
12-18-2013, 11:43 PM | #35 | |
Not sure if you're asking to see options for mounting the manifold/tank/eLevel or how the sensors can be installed(or both), and if you will be doing a raised bed floor or keeping it the bed floor stock. If you are looking for a basic, non-raised floor, stock frame, non dropmember installation of the AccuAir system on the C10, here is how I have mine set up with the space I have available under the bed and between the frame without any modifications. I have a few pics of the sensor mounted as well if you need to see how I ran mine. Hope that helps. |
12-27-2013, 02:07 PM | #36 |
Kill Bill...et
I got lazy and used a pre-made compressor mount. Leaves plenty of room for e-level if I ever go that route. The bed is installed and raised a couple of inches leaving plenty of room for maintenance.
12-27-2013, 09:22 PM | #37 |
Steve, I really like your truck!
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
