12-28-2013, 09:32 PM | #1 |
electrical issues
So, I went to start my truck today, and I turned my heater fan down to use less power to start the truck, and suddenly the heater, blinkers, wipers and aftermarket tach stopped working. I know it some type of short but I was wondering if anyone has any ideas on where to look first
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
12-28-2013, 09:53 PM | #2 |
Re: electrical issues
It still runs? Those are the only circuits dead? Wondering if u lost a fuse/fusible link under the hood. ?
12-29-2013, 01:12 AM | #3 |
Yes it still runs, what was listed above are the only things I could find that dont work. I checked the fuses, none looked to be burned out, but I was going by a dim flashlight in the dark so I will look into it further later on, I have a small feeling it has something to do with my heater controls because of how it was acting before this happened. it is hard to explain how it acted but I will start there and let you know
12-29-2013, 01:32 AM | #4 |
Use a test light. Turn key on and touch each side of the fuse.... Better than the eyeball test. If you have no power there it could be the firewall connector itself. Seen some of them melted too. Work your way towards the battery until you find some power.
12-29-2013, 11:50 AM | #5 |
Sounds like the accessory side of the ign. switch may be bad or a loose connection on it. When the switch is turned to start position the acess. side is turned off.
12-29-2013, 12:19 PM | #6 |
He wouldn't have power to the distributor though... Would run in crank position. But not on/acc
12-30-2013, 05:16 PM | #7 | |
Check the brown wire at the ignition switch, everything you listed is powered by the brown wire. The engine will still run because the ignition gets power from the pink wire.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
12-30-2013, 05:36 PM | #8 | |
Double post.
12-30-2013, 06:22 PM | #9 |
Msgt USAF Ret
Just for illustrative purposes I decided to post up the wiring of the ACC brown wire that the fellows are talking about. I think they have it nailed down and you'll be able to see that in the diagrams.The first one shows the ignition switch wiring and the 12 gauge brown ACC wire on the switch.
This one shows the ACC wire going to the fuse panel and feeding the Heater,wiper,and turn signal fuses. It is indicated by the black arrows. The brown wire near it is the heater switch feed wire, the yellow wire is the windshield wiper motor wire, and the purple wire is for the turn signals. It runs from the fuse panel to the steering column connector and up to the turn signal switch.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-30-2013, 06:39 PM | #10 |
Great info guys
12-30-2013, 10:56 PM | #11 |
yes, exactly I will look further into this tomorrow
01-01-2014, 01:23 PM | #12 |
Okay, I looked further into it, and I believe that the brown wire is pulled mostly out of the ignition switch but it seemed too small of a wire to run all of that stuff. Also it still is partially starched to the switch and with the key on, it accidentally hit the dash and sparked but won't do it again, and no fuses are blown either never mind that was the brown white, anyone know what that goes to?
01-01-2014, 01:38 PM | #13 |
The only wired I have starched to the switch are: red pink purple brown-white and a light brown wired probably about 20 ga the only 12 ga solid brown wire I see goes straight to the heater controls
01-01-2014, 01:43 PM | #14 | |
The Brown/White is the resistance wire going to the voltage regulator. The Brown wire should go to the same terminal. In the pic below it shows 2 brown wires on the terminal next to the purple wire, that is where both the brown and brown/white wires should be terminated.
01-01-2014, 01:52 PM | #15 |
Okay, that helps but I still can't find the brown ire under the dash, which is confusing me, but would that spark to the brown-white wire have possibly knocked out my voltage regulator?
01-01-2014, 01:54 PM | #16 | |
That wire is coming from the fused side of the fuse box, there should be another brown wire coming from the hot side of the fuse box going to the ignition switch. Look around, I suspect it probably broke off from the terminal.
01-01-2014, 01:57 PM | #17 | ||
Try tracing the brown wire from the fuse box and work your way back to the switch. It could be that a PO changed the wire color in a previous repair.
01-01-2014, 02:00 PM | #18 |
I would assume that this acc wire would still come from the main wire bundle that does up and around the steering column, and if this is the case there is only 1 12 ga wire coming from there which goes straight to the heater controls
01-01-2014, 02:02 PM | #19 | |
Start at the fuse box and work your way back to the switch. It could be that a PO changed the wire color in a previous repair.
01-01-2014, 02:05 PM | #20 |
Will do but I may as well ask, there are repeat wired connected to a connector and only one wire coming our the other end and that not connected to anything, any ideas what that would be for?
01-01-2014, 02:14 PM | #21 | |
Impossible to tell without seeing it because it is not stock and probably part of a PO hack job. Best thing to do is to identify all the wires and with the schematic find out where they are supposed to go to, then correct things from there bringing it back to stock. If you don't have a schematic PM me your e-mail address and I'll send you one, I tried to attach it but it is too big.
01-01-2014, 02:18 PM | #22 |
That what I figured but what I don't get is everything worked fine until Saturday night so if it is the ignition switch there should be a wire somewhere near it
01-01-2014, 02:21 PM | #23 |
Here is a slightly crappy photo of my ign.
01-01-2014, 04:57 PM | #24 |
Problem solved, loose connection at the fuse box
