Old 01-06-2014, 02:32 PM   #1
SawyerBeavers
Installing "Custom" cab moldings
So I bought these cab moldings for my 65 longbed but not quite sure how I want to go about putting them on just yet. Any ideas?? I know I've really only got about 2 choices, glue it or drill it on there. Just curious what you guys have done and what's worked and hasn't.
SawyerBeavers is offline   Reply With Quote
Old 01-06-2014, 02:36 PM   #2
MisterC
MisterC's Avatar
Re: Installing "Custom" cab moldings
You should drill pilot holes for the screws and then pick up a set of replacement screws from any of the classic truck supply shops (LMC, Classic Parts, Brothers). They all have the screws, they're stainless, and very inexpensive.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 01-06-2014, 02:41 PM   #3
wjjeeper
wjjeeper's Avatar
I used 3M double sided tape.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 01-06-2014, 02:47 PM   #4
SawyerBeavers
Its somewhat of a tight fit where the molding meets the edge of the door. Would tape make it stick out too far? or would the heads of the screws stick out too far? Do you think this could be a different problem related to the position of the door?
Old 01-06-2014, 02:59 PM   #5
wjjeeper
wjjeeper's Avatar
I used the double sided tape on the leading edge and there's no impact with the door.
This solution worked for me as I didn't want to drill holes in my cab.
Old 01-06-2014, 03:19 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
Easiest thing would be double side tape...but I would screw it on just for the fact of knowing that they won't fly or fall off.
Old 01-06-2014, 04:02 PM   #7
1963c-10
1963c-10's Avatar
Id go with the factory option and get the 4 screws that they each take.
1964 Short bed trailer
Old 01-06-2014, 08:55 PM   #8
NEWFISHER
NEWFISHER's Avatar
And use double sided tape at the upper, outer corners to secure the top portion if you don't have the brackets. Stack up the tape in a 2 inch section
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 01-07-2014, 02:54 PM   #9
SawyerBeavers
Does anyone have a link to a site that sells the hardware? I just checked classic parts an they don't sell just the screws.
1965 c10, advice, cab trim, custom, molding
