02-14-2014, 09:39 PM | #1 |
Frame question
Hi guy's
I just bought a 69 C10 SWB fleetside pretty much stock other than having front & rear roll pans & it's not ugly but it's not me I guess I'm just old school & love the bumper look on these trucks so I looked under it to see what I need to do to remove the roll pans & WoW the PO or the guy he paid to install them cut the front frame rail tips to install them :/ Well now I'm in search of a frame so that I can be able to bolt the front bumpers back on. So I was wondering if the frames on these trucks are the same from 67-71? Just good to know because SWB frames are hard to fined & probably even more so by looking for only 69 SWB frames. Thank you for your time |
02-14-2014, 10:04 PM | #2 |
Hollister Road Co.
Re: Frame question
I won't re-frame it for that, i'd get any frame from 67 -72 and cut off the pieces I need to repair the original
02-14-2014, 10:07 PM | #3 |
Re: Frame question
I would do as mentioned above ,buy the ends and graft them back on .
02-14-2014, 10:49 PM | #4 |
Re: Frame question
Yeah I thought about that but who would sell me just the ends or where can I buy them?
If you had a frame & I went over there & cut the ends well your stuck with scrap metal? I don't plan on ever selling the truck so building a ground up resto on a (Titled!!)frame won't hurt me You see I'm going to redo the complete suspension with disc on all 4 corners so I would paint it & put it side by side & build from one side to the other. |
02-14-2014, 11:22 PM | #5 |
Re: Frame question
Check out the parts forum here ,someone is always parting out old trucks and they may have a frame that has damage somewhere and be willing to cut you out what you need .
02-14-2014, 11:42 PM | #6 |
Re: Frame question
Thank you I'll try that
And guy's remember if you see those front roll pans in your catalog ask yourself do you really want to chop up your frame? Last edited by N2TRUX; 02-24-2014 at 11:11 AM. |
02-15-2014, 08:46 AM | #7 |
motor exploder
Re: Frame question
Too bad you didn't post this thread before I hauled off my scrap metal
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
02-15-2014, 09:17 AM | #8 |
Re: Frame question
Yeah that's how my truck looks like & like I said it's not ugly but I would never chop up my frame & I hope you don't run into something that roll pan is like having a beer can for a bumper
02-15-2014, 11:22 AM | #9 |
motor exploder
Re: Frame question
Why don't you just weld some plate back onto the framerail stubs and drill the holes for the bumper mounts? There are plenty of diagrams available here on the forum that give the exact dimensions of where the bumper mounts up. If you think taking 2" off the front framerails is 'chopping up' a frame, you'd really hate what I did to the rest of my truck!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 02-16-2014 at 09:36 AM. |
02-15-2014, 12:48 PM | #10 |
Re: Frame question
Sorry I didn't explain myself but who ever did the roll pan on my truck chopped it off with a blowtorch & it looks like a 5 year old did it
If I do cuts I do it right & I would have saved the ends so that they can be but back on if need be. Cutting for suspension upgrades doesn't bother me because it's that an upgrade |
02-15-2014, 02:15 PM | #11 |
Re: Frame question
What boss hog said it's not rocket science
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
02-15-2014, 02:40 PM | #12 |
Re: Frame question
Lol
02-15-2014, 03:42 PM | #13 |
motor exploder
Re: Frame question
Here's a layout just in case you get a wild hair. Even if you locate a set of framerail tips to graft on, you will probably still need this so you can get them back to stock spec if you plan on using OE style brackets and a replacement bumper.
02-15-2014, 03:51 PM | #14 |
Re: Frame question
Thank you Adam I appreciate you taking the time to do that
02-15-2014, 10:44 PM | #15 | |
Re: Frame question
Much easier than swapping frames.
02-20-2014, 12:35 AM | #16 |
Re: Frame question
Ill betcha theres at least 5 guys on the for sale forum willing to sawz-all a frame for you. Just tell them how far back you need them to cut.
1967custom |
02-20-2014, 12:59 AM | #17 |
Re: Frame question
I almost bought a frame in your hometown but U-Haul fees (1,200) kept me from doing that.
Thanx but I may have found one already I'll find out tomorrow? |
02-20-2014, 04:49 PM | #18 |
Re: Frame question
Yeah u hauls gotten rediculous. Theres good frames here. I know alot of members here kike buying parts from nm az and southern ca.
1967custom |
02-23-2014, 06:24 PM | #19 |
Re: Frame question
Found a frame already guys thanks for all your help
