Old 08-08-2014, 07:09 PM   #1
'53 Flat Bed
LS1 Swap Exhaust Manifold or are Headers a must?
This is my first post on this awesome forum. Been reading for a while.
I have a 1953 3100 that I am building with IFS and four link rear with a ford 9 inch rear end. I am putting an LS1 and 4l60E from a 2001 Camaro in it.
So the question is are there any stock LS exhaust manifold that will work without having to cut into the frame? Or are headers the only way to go and if so which ones will work? Does it have to be the block hugger or do shortys work?
This is not a high performance build. This will be a daily driver I am not concerned with horse power but prefer better gas mileage.
'53 Flat Bed is offline   Reply With Quote
Old 08-08-2014, 08:13 PM   #2
Iceburgh
Iceburgh's Avatar
Re: LS1 Swap Exhaust Manifold or are Headers a must?
Look over under LS swaps under the engine thread. There are a bunch of post about this.
Many ideas but much of it will depend on where and how you have your engine mounted.
I used Dirty Dingo mounts and long tubes.
Your going to need something that sweeps back for sure
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 08-08-2014, 08:43 PM   #3
'53 Flat Bed
I thought I would ask here because I didn't see anything for the AD trucks, it seemed to be for other years and frame dimensions are different.
Old 08-08-2014, 09:18 PM   #4
slimneverdies
slimneverdies's Avatar
Depends on where you have your engine placed for sure. I have the original manifolds from my ls1 on my 53 and the collectors are barely clearing but I did place the engine a bit higher than originally planned cause of this and the rack and pinion.
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-08-2014, 11:03 PM   #5
Iceburgh
Iceburgh's Avatar
I you want to go the header route then Sanderson makes a set that bolts u with no issue with a AD and MustangII
They are a little salty but nice
1953 suburban build
Old 08-10-2014, 11:06 AM   #6
skymangs
skymangs's Avatar
Check out Headman, cast iron headers. $300 well spent. They are designed after the stock Trailblazer SS manifolds. Very tight fitting.
skymangs is offline   Reply With Quote
Old 08-10-2014, 11:15 AM   #7
not2oldchevy
Early c5 corvette manifolds work with no modifications.
not2oldchevy is offline   Reply With Quote
Old 08-10-2014, 03:30 PM   #8
torchlight
torchlight's Avatar
Yep, Corvette manifolds is what I've always read for something stock that fits without going to custom headers.
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 08-10-2014, 04:11 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
I think it depends on what suspension and where you set the engine. I have seen guys use Vette manifolds with no problem but I ended up using a left SS Trailblazer and a right Escaldae manifold. Vette manifolds just would not fit for me
Old 08-10-2014, 09:05 PM   #10
Root2812
Root2812's Avatar
I used LS6 exhaust manifolds from an 02 Corvette. $75 for the pair made it a cheap solution.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 08-10-2014, 10:13 PM   #11
'53 Flat Bed
Anybody have pictures of the Corvette and Trailblazer SS installed they would be willing to share?
Old 08-10-2014, 10:21 PM   #12
dwcsr
Hollister Road Co.
dwcsr's Avatar
This is the SS tralblazer right , Cadilac CTS left. I said Escalde before but it was CTS
If the engine was set a little higher I could have used two trailblazer manifolds
Old 08-12-2014, 01:25 PM   #13
'53 Flat Bed
So what years did the CTS use that manifold?
Old 08-12-2014, 09:33 PM   #14
dwcsr
Hollister Road Co.
dwcsr's Avatar
Originally Posted by '53 flat bed View Post
so what years did the cts use that manifold?
6.0 cadillac cts 2004 2005 2006 2007
Old 08-13-2014, 08:00 AM   #15
47 Fasttoys
47 Fasttoys's Avatar
Wink Re: LS1 Swap Exhaust Manifold or are Headers a must?
I don't see what the clearance issue is....mine fit with loads of room. LOL, Sorry just being a smart ass.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 08-13-2014, 11:19 AM   #16
'53 Flat Bed
I wish I had that much clearance. I love COE and wanted to buy one but I couldn't pass up the deal that I got. Here are some pics of my project.
Custom made bed
I set the engine in yesterday. Here is how it sits.
Old 08-13-2014, 04:36 PM   #17
iowaboynca
iowaboynca's Avatar
Looks good. Should set up a build thread.
iowaboynca is offline   Reply With Quote
Old 08-16-2014, 02:26 PM   #18
Root2812
Root2812's Avatar
That looks great. You are a bit farther along than I am on mine. Did you have to trim the firewall? I have my LS in between the frame rails on adjustable mounts but the cab has not been on yet.
My 1950 Chevy build
Old 08-16-2014, 04:03 PM   #19
'53 Flat Bed
No, I didn't have to change anything to do with the fire wall. I purchase the truck with he IFS in it already and it had motor mounts for a small block installed. I made the adapter plate for the LS motor and in it went. It sits 3/4 of inch in front of the fire wall. One of the previous pictures shows the spacing taken down across the fire wall to the back of the engine.
I did decide to go with some hooker headers. I will post pictures as soon as I put them in place.
Old 08-16-2014, 05:01 PM   #20
'53 Flat Bed
I should clarify, I actually ordered Hooker Header exhaust manifold 520-8501.
1953 truck, exhaust manifold, ls1, shortys
