08-30-2014, 05:48 PM | #1 |
K20 10 Bolt 8 Lug Help
I am trying to tear down this axle and I ran into an issue. After I removed the locking hubs there is a sleeve in the hub that doesn't seem to be removable and it is blocking the spanner nut. The axle is from a '78 K20 and has internal hubs. I attached a picture of what I am talking about. Any help?
08-30-2014, 06:09 PM | #2 |
Re: K20 10 Bolt 8 Lug Help
Clean off the grease and I suspect you will find a snap ring to be removed.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
08-30-2014, 06:13 PM | #3 |
there is a snap ring rite there that needs to be taken off reach around the backside of the axleshaft and it will push back to you and you see it also there is a tab that needs to be bent up so your socket will go over it
4x4k30 if trouble was money i would have plenty |
09-01-2014, 03:58 PM | #4 |
OK, I cleaned off all the grease. The pic in post #1 the outer locking nut is loose and is over this ring. On the other side, it is all tightened down properly and I think I see the snap ring but if that is it, it won't budge. Any suggestions? Thanks in advance.
Here is pic of side with outer locking ring loosened and a pic of the side where all nuts/rings are tightened down. |
09-02-2014, 11:07 AM | #5 |
Please take a look at this crude Paint creation. Is the red arrow the snap ring you are speaking of the remove the sleeve that the blue arrow is pointing to? If where the red arrow is is the snap ring then I can't get it to budge. Thanks!
09-02-2014, 03:22 PM | #6 |
Anyone know how to get the ring that the blue arrow is pointing to out?
09-03-2014, 02:56 AM | #7 |
Second Chance Program
THat should just pull out. I like to use my dental tool if i cant grab it with needle noses.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
09-03-2014, 09:41 AM | #8 |
Does the whole ring with all the teeth on it just pull out or were you referring to the smooth ring on the inside of that (somewhat resembles a bearing race)?
09-03-2014, 01:44 PM | #9 |
I am having a hell of a time figuring out how to get this hub/rotor off. I understand the principal and how to remove the axle nuts but I cant get this ring out (I believe it is called a clutch ring or axle sleeve?). There also appears to be a washer or some type of snap ring that is frozen on the axle shaft itself. In pics above, blue arrow is the "ring" and red arrow is the "snap ring." Anyone have any ideas? Maybe I should ask the mods to move this thread to 4X4 or suspension sections.
09-03-2014, 08:11 PM | #10 |
78K & 79C Jimmys
the hub ring i've seen ,looks different but i'd say look in here
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-03-2014, 08:35 PM | #11 |
The red arrow you have pointing the spindle. It stays in place.
The blue arrow is part of the locking hub. It should just pull out.
09-03-2014, 08:38 PM | #12 |
You seem to be pointing at the hub snap ring which it appears mv has already removed. Thats #7 in the above diagram.
09-04-2014, 09:23 AM | #13 | |
78K & 79C Jimmys
found this pic I was thinking of these type snap rings,says auto hubs tho
09-04-2014, 10:59 AM | #14 | |
So I should just be able to reach behind this geared ring (makes sense now that I know it is part of the locking hub) and pull it out? Just want to make sure we are talking about the same thing. |
09-04-2014, 03:29 PM | #15 |
Correct.
09-08-2014, 11:03 AM | #16 |
Finally got the damn thing out and tore down the rest of the axle. Thanks for the help everyone!
03-04-2015, 09:02 AM | #17 |
In the above diagram, does anybody know where I can purchase # 12? On one side, the bearing/bushing was damaged during dissassembly.
03-04-2015, 11:04 AM | #18 |
Quad4x4.com is a good web site to start. Bruce
03-05-2015, 12:45 AM | #19 |
Moderator
This is the page for your hub from the 73-78 GM Parts Illustration manual.
The clutch is GM Part # 3937062
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 03-05-2015 at 03:52 PM. |
