Old 09-05-2014, 01:03 AM   #76
boynton
boynton's Avatar
Re: 1970 One Owner Short Step
On a different note I have the doors primed and lined up and shutting correctly.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 09-05-2014, 01:12 AM   #77
boynton
boynton's Avatar
Final post for the night is the updated exhaust. I used the stock cats but I had to modify the position. I also had the exhaust shop throw on some 40 series Flowmasters. They are temporarily turned down just before the rear axle until I get the bed on and figure out where I want the exhaust to exit.
1970 SWB Step-Side
Old 09-05-2014, 10:49 AM   #78
rgunlock
rgunlock's Avatar
Dang! There you go passing me up again. Doors are next on my list and you've already done yours. Fuel cell looks good in there, as well as the exhaust.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 09-05-2014, 12:21 PM   #79
boynton
boynton's Avatar
Thanks. Im getting my fuel line worked out today and then hopefully try and crank this thing on Monday. Hoping to make some serious progress in the next moth.
1970 SWB Step-Side
Old 09-16-2014, 10:17 AM   #80
Dean'smeanmachine
Dean'smeanmachine's Avatar
sweet build!
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 09-24-2014, 11:59 AM   #81
boynton
boynton's Avatar
Originally Posted by Dean'smeanmachine View Post
sweet build!
Thanks. It is slowly coming along. I started my side marker fuel filler door. here is where it is so far...still tweaking a few things but I like where I am heading. I do not have my up to date pictures with the side marker installed, but I should get those soon (I forgot to take them!!!) Anyway I am not a metal fab guy I'm just a redneck who has seen it done...dangerous I know!
1970 SWB Step-Side
Old 09-24-2014, 12:08 PM   #82
boynton
boynton's Avatar
I also got my fuel line made and installed. I used the OEM connectors with a rubber fuel line. turned out well and was fairly inexpensive (compared to AN fittings).
1970 SWB Step-Side
Old 09-24-2014, 12:16 PM   #83
boynton
boynton's Avatar
In an attempt to keep the engine bay clutter free, I am going to attempt to mount my PC and my fuse relay in the cab under the dash. I am mocking up some cardboard templates to try to make this work. Since I am using an aftermarket digital gauge cluster, I will have a bit more room behind the gauge cluster VS stock because it is MUCH thinner. I am banking on this room so that I can still run my A/C line to the driver's vent. If I end up not having enough room I will have to fabricate a square a/c box VS the round A/C hose...this is going to be interesting. I also want the PC and fuse relays in the cab so I do not have to worry about them getting wet. I know it is going to be a pain changing a fuse or relay, but I think I am willing to deal with that. Worse case scenario, I have to pull the gauge cluster for direct access. Hopefully once I get all the bugs worked out, I wont be touching these fuses anyway. I will utilize the oem fuse panel to run the lights, radio, ect. Wish me luck, cause I am going to need it!
1970 SWB Step-Side
Old 09-24-2014, 12:19 PM   #84
boynton
boynton's Avatar
While working on the truck, I realized the cross brace that covers the fuel cell is not going to clear the fuel pump...out came the cut off wheel for a quick surgery. Slapped on a little paint and problem solved.
1970 SWB Step-Side
Old 09-24-2014, 02:28 PM   #85
mcbassin
Still Learning
mcbassin's Avatar
Excellent work on the fuel filler and fuel system! It should be a lot easier for you to get fuel to your tank on the step side bed as opposed to the fleetside. There just isn't much room unless you cut into the inside of the bed. Nice work!
I like the idea of putting all the components you can inside the cab too. I know it will be a little more difficult to troubleshoot problems but it sure makes the engine bay clean.
Old 09-26-2014, 02:19 AM   #86
boynton
boynton's Avatar
Thanks. You fuel filler looks much cleaner, which is my end goal. Did you have any issues getting the side marker light to sit flush on the recessed mounting place? Or any issues with the fuel door mounting bolts getting in the way?
This has been a learning process for sure. I hope to be able to work the bugs out fairly quickly so that I do not have to mess with the fuse/relay block much if at all. I will have a long road ahead of me cleaning up the engine bay. I will eventually re-route my harness so that it less visible and move the coil packs off of the valve covers, but before we get too fancy I want to get this thing running. I figure all of that can come later on, but I need to mount the relays/pc in the cab now because if I don't, I never will.
1970 SWB Step-Side
Old 09-26-2014, 12:34 PM   #87
Dean'smeanmachine
don't you just love wiring? had one heck of a time figuring out my radio for my truck, still working on it lol great job. great metal working. i love fabbing
Dean
in God we Trust
Old 09-26-2014, 01:04 PM   #88
GAc10boy
GAc10boy's Avatar
Subscribed. Excited to see how the truck turns out. I like you're creativity when trying to save a few dollars here and there!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 09-26-2014, 03:10 PM   #89
mcbassin
Still Learning
mcbassin's Avatar
I did have to make clearance for the heads of the bolts. If you look at the pictures close you can see how I did that HERE. I cut two slots in my lens mounting plate that I welded to the hinge. The lens does stick out a little more than the stock lens but only about a 1/16". Not really even noticeable, in my opinion. It sticks out a little more in the front than in the rear. Again it's really not noticeable. You wouldn't know it's there just looking at the side of the bed.
You are doing a good job and kudos for just jumping into that mod. It was a pain for sure. I spent a ton of time on mine. I've since forgot how many hours....but the next one I do I'll have a pattern to look at.
Old 10-01-2014, 12:50 PM   #90
w00dst0ck
w00dst0ck's Avatar
Was the high hump a necessity?
w00dst0ck is offline   Reply With Quote
Old 10-01-2014, 01:42 PM   #91
boynton
boynton's Avatar
Yes it was. Unless you modify your low hump you will need a high hump. It would takes more modification than I could justify and since there are so many high humps sitting around and they are so easy (compared to modifying the floor pan) to install it was the call for me.
1970 SWB Step-Side
Old 10-01-2014, 02:35 PM   #92
w00dst0ck
w00dst0ck's Avatar
High humps aren't as easy to come by in the 64-66's it seems :/
I'm doing this exact swap right now.
Old 10-01-2014, 06:06 PM   #93
boynton
boynton's Avatar
haha well I am learning as I go. Every time I build a truck I learn more. This is by far my most aggressive build.
Thanks. This is the only way I can sorta afford this build! It really hasn't been terrible ($) so far. I will try to put a list together of what I spent when I am done. I am trying to keep track of everything I use and spend!
Thanks. I am pretty sure your install is much prettier
1970 SWB Step-Side
Old 10-01-2014, 06:10 PM   #94
boynton
boynton's Avatar
hmmm I wonder how hard it would be to use/modify a 67-72 high hump for your truck...or maybe a 73-87 floor pan could come in handy? I have no time working on your era of trucks. I am sure that someone on this forum knows exactly what to use though.
1970 SWB Step-Side
Old 10-01-2014, 08:25 PM   #95
04sshd
04sshd's Avatar
wow, you're not wasting any time! Nice build!
1968 Chevy C-10 Suburban - 350/350
1969 Chevy C-10 Panel Delivery - 454/400
1972 GMC K1500 Jimmy - 350/350/np205
1978 Chevy Corvette Silver 25th Anniversary
reddit.com/r/chevyc10 <-Join it!
04sshd is offline   Reply With Quote
Old 10-28-2014, 01:47 AM   #96
boynton
boynton's Avatar
I haven't updated in a while, but here is a preview of when I get a chance...
1970 SWB Step-Side
Old 10-28-2014, 08:14 AM   #97
Low Elco
Nice stuff!
Low Elco is offline   Reply With Quote
Old 10-28-2014, 01:13 PM   #98
GAc10boy
GAc10boy's Avatar
Very nice! Love the green.
- Robbie
Old 10-28-2014, 01:29 PM   #99
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great!! Love the color combination. Fab work is looking good too. Keep it up
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 10-28-2014, 09:43 PM   #100
boynton
boynton's Avatar
Originally Posted by Low Elco View Post
Nice stuff!
Thanks.
It is 1970 504/506 factory colors. Both of these colors have flake in them and look amazing in the sun. I'll try to get some good pictures soon, these pictures were taken early in the morning in the shade and don't do the paint job justice. My paint guy made enough paint so we can shoot it in stages and not have any issues.
Thanks I was a little nervous but when I saw it laid out I really like it.
1970 SWB Step-Side
