Old 10-31-2014, 01:54 PM   #1
60_Apache
Question 66 C10 6 Lug Float Disk brake conversion from 90s K1500 pick up
Hello
I'm planing to do a 6 Lug Front disk brake conversion on a 1966 C10.
Is it possible to retain the 1966 C10 Hub rotor and wheel bearing.
Then replace the drum with a 6 Lug Float Disk brake from 90s K1500 as shown.
Bolt circle are the same 6 x 5.5"
Hub Reg on the 1990s K1500 Disk brake is slightly small than The Hub Reg on the 1966 C10. Which can be machined to the correct size.
Has any body done this similar conversion recently?
1966 C10 Pick up Drum with bolt circle 6 x 5.5"
1994 K1500 Pick up
60_Apache is offline   Reply With Quote
Old 10-31-2014, 02:42 PM   #2
PGSigns
PGSigns's Avatar
Re: 66 C10 6 Lug Float Disk brake conversion from 90s K1500 pick up
Have not seen that setup tried yet. The 88 and up swap has not been worked out and those who have tried have not had a good time. The 73 to 87 swap is well documented and works well. I have it on both my trucks. The rotors through Summit are not that expensive and it is a proven setup.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-31-2014, 04:52 PM   #3
shortbed70
shortbed70's Avatar
Subscribed...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-01-2014, 05:08 PM   #4
PGSigns
PGSigns's Avatar
Even if you bore the rotor you still need to design a caliper bracket to bolt to the stock spindle and work with the caliper you choose. Wilwood has done this for the camaro drum spindles.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 11-03-2014, 01:08 PM   #5
buds56
buds56's Avatar
I've used this company before with good luck,
Its not a floater but will get you 6 lugs on your spindles
https://scarebird.com/index.php?rout...product_id=150
buds56 is offline   Reply With Quote
conversion, disk brake, float
