Old 12-27-2014, 08:33 PM   #1
Beach Burb
Rear door speaker wire?
Installing 5 1/4 inch speakers in the front two doors of my '71 Burb and allso putting them in the 3rd door and blank door space across from it. Any suggestions on where to place wire loom on the third door and if anyone has had issues with running wire in the back door pillar.
1971 Chev Suburban
1951 Chev 3100 Pickup
1953 Harley 165 ST
Beach Burb is offline   Reply With Quote
Old 12-27-2014, 09:14 PM   #2
vectorit
What?
vectorit's Avatar
Re: Rear door speaker wire?
The best way to run the wires I think, would be from the roof area and run down the pillars. That's where the rear light harness is run from, and there is already a hole for that at the fuse block.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-27-2014, 09:42 PM   #3
Beach Burb
Thanks, I'm running an amp out of a center console so I can run the wire under the flooring. Mainly looking to see of others had any problems with wire loom in that door since it looks like a tight fit between door and pillar.
1971 Chev Suburban
1953 Harley 165 ST
