01-30-2015, 01:17 PM | #1 |
73-87 lift/tire combo pics
Lets see some sick squares!! Post your 1973-1987 k series trucks with the following info,
-Size of lift -size of tires -brand of lift -full spring or blocks just so that people can see how the combos look and help them figure out wich combo they want to do! thanks!! |
01-30-2015, 01:24 PM | #2 |
Re: 73-87 lift/tire combo pics
85 1 ton 8" bds lift all springs with 2" body lift 40x15.5r20
86 gmc short box..461bbc/th400 12.95@106mph 85 gmc crew cab 4x4 8"lift cummins conversion |
01-30-2015, 04:33 PM | #3 |
Those compact spares on the floor look like frisbees compared to your tires!
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
01-30-2015, 09:39 PM | #4 |
3" lift, 33x12.5x15, Rough Country, Springs front, blocks rear
01-31-2015, 12:34 PM | #5 |
6" with 35s seems to be as close to perfect as one can get imo
01-31-2015, 03:42 PM | #6 |
mix-mash
8" skyjacker fr springs & steering gear flips, blocks, & airbags, rr rough country shocks 39" swamps |
01-31-2015, 06:16 PM | #7 |
Gmm that's a awesome looking truck !!!!!!
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-31-2015, 10:09 PM | #8 |
my 83 k20 4in lift 315/75r16 dynapro mt
my 79 k30 3in lift 33x12.50r16.5 bfg at |
02-01-2015, 01:38 AM | #9 |
4" rough country front springs, blocks in rear for now, 35x12.50r15 bfg mud terrains on 15x10 us wheels
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s |
02-01-2015, 01:40 AM | #10 |
Another pic
02-01-2015, 03:30 AM | #11 |
Take a look at http://67-72chevytrucks.com/vboard/s...d.php?t=348743
02-01-2015, 12:21 PM | #12 |
85 w/4" 35s
02-01-2015, 06:43 PM | #13 |
90 jimmy 4 inch springs 36x10.50 tires no clearance issues narrow tire.
02-02-2015, 04:03 PM | #14 | |
almost scrap
02-02-2015, 08:38 PM | #15 |
6" lift, all spring. 36" tires on 16.5" recentered humvee wheels.
02-02-2015, 09:01 PM | #16 |
Junior Member
Front- 8" Superlift HD springs, ORD crossover steering
Rear- 4" ORD shackle flip, 1-1/2 block & zero rate New drivelines ( Inland Truck Parts, North Platte, Ne ) Toyo 38x14.5x16 wrapped on 16x10 Wheel Vintiques Truck rides and drives amazing!
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
02-03-2015, 10:07 AM | #17 |
Just a 2" lift with springs up front and blocks in the rear with bags. 235/85/16's which is almost a 32" tire.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
02-03-2015, 11:09 AM | #18 |
You guys are going to get me in trouble....
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
02-04-2015, 02:50 AM | #19 |
That was with a 6" suspension lift, 3" body lift, Bushwacker Cut-Out Flares, and 38x15.50 Mickey Thompson Baja Claws. The rest are without the body lift. Without the flares, I had to trim the very corners of the front fenders a little. Otherwise they cleared just fine. I used a 16x10 wheel with 5" backspacing, for reference. With the cut-outs, the tires cleared by a mile with only 6" of lift. With the combined 9" of lift and cut-outs, I'm guessing I could have cleared narrow 42's.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
02-07-2015, 12:26 AM | #20 |
Your41Plague12
Do you have any close up pics of your fender trimming? I need to do mine. I would rather not have the wide flares as i run narrow tires. Any info would be great before i start cutting into good metal. Thanks, Chris |
02-07-2015, 09:22 AM | #21 |
02-07-2015, 02:18 PM | #22 |
02-08-2015, 06:06 PM | #23 |
03-05-2015, 01:39 PM | #24 |
Keep Them Comin!
03-05-2015, 04:52 PM | #25 |
85 k20.
Skyjacker 2.5 in front with ORD front shackles. STL Spring 56" rear springs with +1" extra arch and ORD zero rate add a leaf. Bilstein 5100 all 4 corners. 285/75/16 Michelin LTX AT-2 on 16" GM HD powdercoated wheels
1985 GMC K2500. 350/TH400/208. 4:10's. stock. 1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD. |
Tags |
k10, k20, k30, lift, tire |
