02-24-2015, 08:38 PM | #1 |
1/2 ton leaf springs fit on 3/4 ton?
I have 70 gmc 3/4 ton and wanting to lower the rear using new lowering springs but they only advertise for 1/2 tons. Are the rear leafs the same from a 1/2 ton to 3/4 ton or same dimensions? Apologized if this has been covered.
02-25-2015, 10:25 AM | #2 |
Re: 1/2 ton leaf springs fit on 3/4 ton?
From my experience the 1967-1972 1/2 and 3/4 ton 2wd trucks used a 2 ¹/⁴ wide leaf spring. They are interchangeable between 1/2 and 3/4 ton. 4x4 and longhorn are 2.5 wide.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-25-2015, 10:49 AM | #3 |
That has been my experience as well.
