Old 03-06-2015, 01:11 PM   #151
texasld
texasld's Avatar
Re: Project "Leon "
Originally Posted by boynton View Post
I think I will immediately borrow your phone idea with my grill. That is amazing!
Cool! Let's see it!
By the way, did you have to install the heater control valve on your VA system? Ir is that handled inside the condenser kit?
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 03-06-2015, 01:43 PM   #152
Xeen
Xeen's Avatar
Re: Project "Leon "
That Flex Braiding looks nice, I dig it.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 03-06-2015, 01:56 PM   #153
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Project "Leon "
I like the flex braid over the hoses. Looks real clean. Whose braid did you use?, Or rather where did you get it from?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-06-2015, 03:27 PM   #154
texasld
texasld's Avatar
Re: Project "Leon "
Thank's man! Maybe I'll make my upper control arms look nice this weekend too!
I actually have several different "brands" but they all seem to link back to Tech Flex. I got most of it from eBay, but I did run to the local electronics store because I needed a size I didn't have. The upper and lower radiator hoses are wrapped with 1 1/2" braid. Most of the other hoses are covered in 5/8". The thing to note when buying this stuff isn't the "normal" size, but the Min and Max size. The Rad hoses are 1 1/2" and 1 3/4" hoses but the 1 1/2" flex is somewhere in the realm of 1" to 3" min and max.
The trans cooling lines are wrapped in split loom that I got for the LS wiring harnesses. I didn't have enough of the regular to cover those as well.
http://www.ebay.com/itm/291372640050...%3AMEBIDX%3AIT
http://www.ebay.com/itm/231407597789...%3AMEBIDX%3AIT
The heat shrink of 2" or better is a little more tricky to find, but it's out there.
Once you get the hoses covered and the braid tight. Shrink the ends with your heat gun. Something I discovered on accident was, running the heat gun over the flex makes it cinch up a bit more making a cleaner covering. Don't get wild with the heat or it will burn it. I HIGHLY recommend using a heat gun instead of a torch or lighter.
1999 Jeep TJ
Old 03-06-2015, 03:35 PM   #155
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: Project "Leon "
like the idea on wrapping the hoses in that black braid
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 03-06-2015, 04:52 PM   #156
texasld
texasld's Avatar
Re: Project "Leon "
You could always use it as an "Upgrade kit" when you are selling your radiators. If you want to send me a radiator for pictures and such, I would be HAPPY to install it in my truck.
1999 Jeep TJ
Old 03-06-2015, 07:05 PM   #157
knomadd
knomadd's Avatar
Re: Project "Leon "
That braiding looks good. I bet your glad you did it. I know I sure was. It changes the look of the engine bay.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-07-2015, 09:23 PM   #158
texasld
texasld's Avatar
Re: Project "Leon "
Sure am. Thank you big time for sharing the idea! I love the way they look.
1999 Jeep TJ
Old 03-09-2015, 09:13 AM   #159
aggie91
aggie91's Avatar
Re: Project "Leon "
Thanks for the links on the braid. Looked at them and noticed the variety of colors/patterns. Someone could get creative with that stuff.
Karl
The LST Challenge:
Old 03-09-2015, 09:29 AM   #160
texasld
texasld's Avatar
Re: Project "Leon "
Did a bit of test fitting, had to find out where to mount my coil packs. If you look closely in the background you will see the wiring harness! That thing is a mess.
I'm happy with the way the exhaust looks so far, too!
1999 Jeep TJ
Old 03-09-2015, 09:29 AM   #161
texasld
texasld's Avatar
Re: Project "Leon "
No problem, Karl!
1999 Jeep TJ
Old 03-10-2015, 09:49 AM   #162
texasld
texasld's Avatar
Re: Project "Leon "
It's a bit rough, no headers. I'm getting an error code related to the gas pedal, so that and the fact there is no tune for the new cam may have something to do with it...
Let me know what you think.
1999 Jeep TJ
Old 03-10-2015, 09:53 AM   #163
jkeating1
jkeating1's Avatar
Re: Project "Leon "
Dadgum--I gotta speed up my watching to keep up with your building!
While you are fitting, bending, etc., power steering lines--consider the placement of the clip that bolts to the top of the frame and holds the metal part of the hose down to the frame. That clip got loose on mine and the metal-to-metal situation ate into my ps hose. You could use a couple of regular line clamps in lieu of the factory piece. With all the detail you're going to on the lines, you've probably already come up with something really innovative to secure them!
Originally Posted by texasld View Post
Had to get a PS hose made due to the lack of hoses options I had locally and a number of other issues, but I got it done. The return line will be remade and replaced because the bend is to high, I'm going to try the pack it with sand to bend it tighter.
Attachment 1373498
JK
jkeating1 is offline   Reply With Quote
Old 03-10-2015, 10:02 AM   #164
KMC3420
KMC3420's Avatar
Re: Project "Leon "
The end says it all, Haha, YES! Congrats.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 03-10-2015, 12:24 PM   #165
texasld
texasld's Avatar
Re: Project "Leon "
I don't even have the clip. It was missing when I bought the truck. I haven't put a lot of thought into it yet because... well, just because I haven't. Thank you for the heads up though. I may cover the lines in heat shrink or something to make some type of barrier.
Thanks man. I was shaking like a leaf in a Texas tornado with fear, anxiousness and overall happiness!
1999 Jeep TJ
Old 03-10-2015, 12:50 PM   #166
Xeen
Xeen's Avatar
Re: Project "Leon "
Awesome!
It doesn't get more motivational than that, I see a fast paced thrash over the next couple weeks in your future. LOL
Old 03-10-2015, 01:41 PM   #167
texasld
texasld's Avatar
Re: Project "Leon "
Awesome!
You called it! I'm looking for a way out of work for the next few days!
1999 Jeep TJ
Old 03-10-2015, 08:50 PM   #168
sduckworth13
sduckworth13's Avatar
Re: Project "Leon "
Nice job getting it fired up, it sounds mean.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-11-2015, 09:04 AM   #169
texasld
texasld's Avatar
Re: Project "Leon "
Thank you Mr. Scott! Need to get the exhaust finished up. Open headers are pretty loud!
Spent most of my time last night playing with wiring. I fixed the gas pedal, it was pretty easy, forgot to connect the 12v+ for the TAC (Throttle Control Actuator) Module. That will do it every time! Doing some work on making the harness pretty, I think I'm going to stash the ECU under the dash on the side of the brake pedal bracket. I'm moving my fuse block to the upper part of the kick panel on the driver side and run all the chassis wiring through the fender. I really like keeping wiring clean!
The pictures don't show much, but It will get there. I'm laying it all out and taping it up, then I'll pull it all off and loom it in split loom. I'm concerned about the termination of the flex at each connector. I don't want to pull every connector to install heat shrink, and I'm afraid black E-tape wont give me the look i'm going for.
Anyone have any suggestions?
Before
After Dosent look like much happened, it looks worse, actually. But it's in the details, check the valve covers. .
Name:  Pas side wiring.jpg
1999 Jeep TJ
Old 03-11-2015, 11:05 AM   #170
mcbassin
Still Learning
mcbassin's Avatar
Re: Project "Leon "
Congrats on getting her running! Sounds great. I really like the relocation of the coil packs and the sweet valve covers. I hope to do that on mine some day!
Old 03-12-2015, 09:19 AM   #171
texasld
texasld's Avatar
Re: Project "Leon "
Thank you, sir!
Really happy I did them. Not really all that cost effective, but does a number on engine appearance.
More wiring re-working. cut, shortened, soldered, and heat shrinked about 30 different wires. I got all of the engine wiring done, Transmission wires are next. I love making wires look pretty! I used E-tape, and it doesn't look all that great, but it gets it nice and tight. Then I'll go back over and cover with the split braid sleeving. I think one more evening working on it, and I'll have it whipped. Takes more time than you think.
I have to go over to my buddy/painters shop tonight after work to get his two post lift working. Been doing side work for him in his shop to do some horse trading on a nice black paint job! This just adds to the tab.
Before
Name:  Wiring before.jpg
Name:  Wiring before (2).jpg
After
Name:  Wiring loomed 2.jpg
1999 Jeep TJ
Old 03-13-2015, 12:04 AM   #172
trkfrk
trkfrk's Avatar
Re: Project "Leon "
Your motor sounds great! Cool video, nothing like that initial start-up keep the updates coming.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 03-13-2015, 09:54 AM   #173
texasld
texasld's Avatar
Re: Project "Leon "
Thank you, Mark!
I wish I was as close as you are!
1999 Jeep TJ
Old 03-18-2015, 10:27 AM   #174
texasld
texasld's Avatar
Re: Project "Leon "
Spent more time on the main harness over the weekend... what a workout.
Dressed up my coil pack wiring friday night. I like the way they turned out. I mounted the coil packs last week to the tow board on the cab. Finally got some pictures of that. Over the last two nights I have worked on the exhaust. I really like the u-fit kit, but the way I'm going about it is very time consuming, but it's like a super puzzle, with angles! I like Puzzles!
On the coil pack harness, they were covered in a fabric style tape that was IMO pretty ugly. In conjunction with the rest of the wiring, I wanted to wrap it in the flex braid split. I also shortened one of the leads to make it sit better with the new coil pack brackets.
Before
Name:  Coil Harness Before.jpg
During
Name:  Coil Harness buring.jpg
After
Name:  Coil Pack harness after.jpg
Also finished up the looming of the injector/TBA/MAF leads and the transmission wiring.
I really like this split braid stuff!
1999 Jeep TJ
Old 03-18-2015, 10:58 AM   #175
texasld
texasld's Avatar
Re: Project "Leon "
Here are some pictures of the exhaust. It's just tacked together. I don't know about the mufflers, they may end up being way too loud for my liking. They are Flowmaster Outlaw series.... we shall see. I need to add one more hanger for the PS and then onto the other side.
I'm concerned that the trailing arm is going to hit the exhaust. I'll see about that too. What do you guys think? I placed the v-band clamps just after the center trailing arm, this will allow me to remove the transmission w/o cutting the exhaust.
Name:  Pass Exhaust 1.jpg
I need to wash this thing...
1999 Jeep TJ
