#226 |
![]() Join Date: May 2011
Re: 55-57 one piece windows
What might have helped here would have been to weld a flat piece of metal where this little bracket went, that way one could fill the holes with weld. I still haven't welded the holes up!
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com Last edited by Denee007; 10-14-2013 at 06:41 PM. Reason: added info |
#227 |
Ok, that may explain my need to move the front track so far forward.
I drilled the 4 spot welds, cut the slot and relocated the track in the slot. I just never removed the bracket from the bottom of the rear track, just spot welded it back to the door in the new position. I then had to move the bottom of the new front track forward about 1-1/2" to get the window to go down all the way. It works okay, just left me a mess of holes to weld up and do body work on. I bet if I'd cut that bracket, I could have kept the front track at the first place I drilled for it. I'll get this figured out...just in time to never do it again. Thanks for your help.
Old Crow '54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ |
#228 |
![]() Join Date: Nov 2008
Thats what i did to the driver side, works good but dont weld it back until you fit the window in and it working and lining up propely. Welded mine too early and it off a bit now the truck is painted i have to live with it. On the pass side i didn't drill the spot weld instead i cut the track off that bracket from the inside with a die grinder and a small cutting wheel then used whats left of the bracket to line up the track work really good and kept the window in line .
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#229 |
Well, did the driver's side as the video suggests and removed the bracket. Got it first try! Used Denee's idea of welding a flat plate on the end of the track and it works great now. Used paint sticks and urethane to space and secure the run channel around the window opening. When that urethane hardens, I'll use a bit more to secure the bottom half of the run channel in the new front track. Still kept the clip in the rear one, so it's good back there.
All in all the mod isn't that hard to do if you pay attention to the videos the first few times you watch 'em. Wouldn't be afraid to do it again, now, but still, I'm too attached to my wind wings to ever do it to my personal trucks.
#230 |
My idea worked~!?! I'm so happy! I'm happy that you got it all figured out! It will be nice when you're all done
![]() dne'
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
#231 |
man!!!! thanks everyone for all the input on how this should be done.. I have glued my vents shut because of wind noise,, I will be doing this one piece window treatment to my truck soon! again thank you for the videos!! I have watched them several times and will do so a few more!!
Tinker |
#232 |
I see the title of this thread is 55-57 one piece windows, but it will work on a 59 too right?? I hope so, I already have the glass being cut and tempered. Just weird it isn't 55-59. Thought I would double check before tearing into it. Thanks!
Aaron |
#233 |
Hi Aaron from Oregon! A belated welcome to you!
![]() ![]() dne' ![]() ![]()
#234 | |
BTW, thank you so much to the guys that put all of the work into this post. These posts are the biggest beauty of the internet. I appreciate it! Aaron |
#235 |
I didn't use the template that was posted. I bought my entire window set from Brothers Trucks when it was on sale a few years ago. I think you should be OK as I've never read anyone having any problems. On mine the seal is great and wind noise minimal.
The pic below is a mock up window to use instead of the glass for "roughing it in". Made of about the same thickness as the glass. Just need to put a couple holes in it for "handles" or something to grab on to. This is not my idea~ I take no credit for it ![]() dne' ![]()
#236 |
I used the template for my modifications, but left the front track loose so I could adjust if the windows were off a little. Then I bought a set of Brothers windows from a member. I compared the Brothers to the template and the only difference is minor at the back bottom corner (lower right in Denees photo), the angle of the short section is slightly different, like an 1/8" or so. That section is below the sill so sealing in the channel will not be an issue.
#237 |
Perfect, thank you!
#238 |
![]() Join Date: Jan 2013
Alright alright alright. After I posted about one piece window kits in the 55-59 Chevy truck group on fezbook someone posted the link to this thread. So glad they did. Definitely gonna be doing this in the near near future....
So thanks to the guys that made this possible!
WWW.TASKFORCEERA.COM '47-'59 Chevrolet Truck Clothing |
#239 |
Just did this conversion on a '59 I am getting ready to flip. Came out nice! Makes them look like they are moving just sitting there the way the window leans forward.
#240 |
where is everyone getting track seals and scrapers? and does anyone regret this mod? I'm at the point of no return... LOL I will have working A/C , and I cant stand driving anything I own with the windows down because of wind noise. not that I would never. I really like the look of one piece and I'm ready to make the leap....
http://67-72chevytrucks.com/vboard/s...d.php?t=627984 |
#241 |
Read the whole thread, lots of info in it.
Retired and too busy to work. |
#242 |
Hi KingMike! I bought my one piece windows from Brothers, so the wipers came and tracks came with the kit. Still modifications have to be made which you may have read about? I never had the priveledge of riding with the original wings. However my past 57 Chevy Bel-air had them, and I must admit it was nice being able to direct air from outside in. However, I have no regrets as the single glass looks nice and works well!
dne' ![]()
#243 |
Here's the '59 we did for a guy in Texas last year. It came out pretty good.
We used the Brother's kit and a lot of help from this forum to get them right. ![]()
#244 |
has anyone completed this one piece window with the bear claw latches? I seen the video where it might not work? Thanks Tinker
#245 |
Mine made it in OK...
Just plan ahead!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
#246 |
Thanks Bob,, I assume you did the windows first, then the bear claw!! make sense!!
Tinker |
#247 |
Windows first, then claw. Correct. It was a little tight...
#248 |
Hows everybody doing? I just bought a 1955 chevy truck however the top was chopped and came with no windows. Im interested in doing this however I do not have the vent window components in order to re use the track. Anybody know where I can get a track to use?
#249 |
You really should read the whole thread, lots of info. If you had you would have seen my post here, http://67-72chevytrucks.com/vboard/s...&postcount=189
about making your own track.
#250 |
![]() Join Date: Aug 2010
Just want to start by saying a huge thank you for putting this mod together and so in depth. You are truly an asset and inspire me to help out in the truck community more often. I read all ten pages but, could not find a definite answer for my question. Has anyone ran this mod with the trique bolt in bear claw latches successfully? Has Brothers fixed their kits yet?
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
