Old 04-16-2015, 02:32 PM   #1
WATSON403
Lo stalling lowering coils need answer ASAP
So I have a quick and maybe dumb question but I'm installing lowering coils front and back and I'm in the process of taking the old front coils out and I'm wondering if I'm supposed to split the upper or lower ball joint or if it really matters and if I can do this without splitting the tie rod cause the cotter pin is anll bent to **** and in a weird angle thanks a lot!
WATSON403 is offline   Reply With Quote
Old 04-16-2015, 02:52 PM   #2
Evoracer
Re: Lo stalling lowering coils need answer ASAP
Separate the lower ball joint from the spindle. You don't have to mess with the tie rod.
Evoracer is offline   Reply With Quote
Old 04-16-2015, 02:54 PM   #3
WATSON403
Ok thanks it just looks like it would be so much easier to separate the upper
Old 04-16-2015, 02:55 PM   #4
Rust-O-Matic
Rust-O-Matic's Avatar
I don't know what the "correct" procedure is, but I split the top ones on my '66. No need to touch the tie rod ends. You will need to take the rubber brake line loose if you split the top ball joint, because the spindle/brakes/etc. will go down with the lower control arm. If you split the bottom joint this is probably not necessary. My upper joint was easier to get to though.
I'm sure you are already aware, but be sure to put the truck on stands and keep a jack under the lower arm to slowly let it down once the ball joint is separated. There's a sh*t-ton of pressure trapped in that spring, and it will fly out of there and ruin your day (or life) if not handled correctly.
Rust-O-Matic is offline   Reply With Quote
Old 04-16-2015, 02:56 PM   #5
WATSON403
Ok thanks I'm gunna do the upper I didn't know about the brake line thanks
Old 04-16-2015, 02:58 PM   #6
Evoracer
I split the lower as to not have to juggle the weight of the spindle & brake set up. Ymmv
Old 04-16-2015, 03:19 PM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Do the lower and save yourself a lot of hassle of dealing with the spindle, brake lines, etc. You have to get the lower arm really low (almost vertical) to get the springs in and out. I highly recommend you throw a chain or tie down through the spring and lower arm so it doesn't come shooting out and seriously hurt you or someone.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-16-2015, 04:33 PM   #8
WATSON403
I split the top ball joints and got the springs out with not much hassle the worst part was the damn cotter pins
Old 04-17-2015, 05:20 AM   #9
brokenspoke
brokenspoke's Avatar
If the cotter pins are your biggest problem your home free...
brokenspoke is offline   Reply With Quote
Old 04-18-2015, 12:53 PM   #10
nxtruck
nxtruck's Avatar
X2. This is the way I used to replace the springs in my '65.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
1966, c20, coils, lowering, suspension
