Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 07-16-2015, 11:32 AM   #1
kajf9491
kajf9491's Avatar
Correct Wire Gauge Selection
I'm hoping some of you much more knowledgeable and experience members may be able to easily answer this for me. I've been slowly working through different electrical issues with my 72' longbed but I haven't been able to find anywhere that recommends what gauge wire should be used. I think I bought a few spools of 16ga and that's what I've been using but I'd feel much more comfortable if I knew this was correct. Any Recommendations?
kajf9491 is offline   Reply With Quote
Old 07-16-2015, 12:33 PM   #2
SS Tim
SS Tim's Avatar
Re: Correct Wire Gauge Selection
The factory service manual has the wiring diagrams indicating color and wire gauge for most of the circuits. They can be found in section 12. Most of The generic charts do the same but often come up short on option wiring.
RTFM ... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
Old 07-16-2015, 01:21 PM   #3
kajf9491
kajf9491's Avatar
Thanks TIM! That link to the manuals is like gold! You probably just gave me access to the answers for hundreds of questions I would have had.
Old 07-16-2015, 01:36 PM   #4
87Skier
87Skier's Avatar
Some general rules:
Low current stuff (less than 5 amps) - 18 awg (Side marker lights, relay control wires, instrument lights)
Med current (5-10 amps) - 16 awg (Tail lights)
Med-high current (around 10-15 amps) - 14 awg (Headlights)
High current (20+ amps) - 12 awg (Coil wire, heater fan)
Over 30 amps you will have to size to what you are doing.
Size a little bigger than you need. If you are doing a long wire run, you may need to upsize your wire. Don't be tempted to use 20 awg and higher number wire for automotive stuff.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 07-16-2015, 02:26 PM   #5
FirstOwner69
FirstOwner69's Avatar
Gauges and colors shown here:
http://67-72chevytrucks.com/vboard/s...d.php?t=185665
FirstOwner69 is offline   Reply With Quote
Old 07-16-2015, 05:01 PM   #6
jabborabbo
jabborabbo's Avatar
I would add to make sure EVERYTHING is appropriately fused...for instance, in my '67 the cigarette lighter originally had a 12 gauge wire running to a hot terminal in the fuse box...no fuse...I connected a fused jumper between that wire and the fuse box. Better to blow a fuse rather than melt a lighter or a wire....
jabborabbo is online now   Reply With Quote
Old 07-16-2015, 11:37 PM   #7
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Funny, but to me that's the most dangerous circuit in the truck.
Fuse. Fuse all the way.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 07-17-2015, 12:10 AM   #8
centuryhouse
centuryhouse's Avatar
Because it is NEVER fun to be driving down the highway one night and have smoke come pouring out from under your dash. Ask me how I know
Oh that 67 Mustang was a fun car....but I knew nothing about wire gauge requirements when I rewired some of it.
centuryhouse is offline   Reply With Quote
Old 07-17-2015, 05:11 PM   #9
dirtyjim
dirtyjim's Avatar
here is a handy dandy wire chart
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
electrical, wiring
