Frame swap
Can anyone confirm if a 64 C10 frame will work under a 71 body, cab mounts, bed mounts, and core support?? I've also seen threads that mention S/10 frames as well... Any info would be greatly appreciated. I've searched the forums and have found information that is close but doesn't confirm my question. I have eyeballed it and it looks the same just have never taken a tape measure to it..
![]() Join Date: Sep 2007
Re: Frame swap
mounting locations will be different and you will have drum brakes in the front but the frame width should be the same
1967custom |
