Old 08-12-2015, 07:24 PM   #1
Brave71
1971 big block
What would a stock 71 running big block with alt , ac comp power steering sell for? Probably need rebuild
Brave71 is offline   Reply With Quote
Old 08-12-2015, 08:10 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 1971 big block
$300 bucks...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-12-2015, 08:15 PM   #3
Jurassic-1
Jurassic-1's Avatar
Re: 1971 big block
Out here if it is complete we usually pay around $800 for one complete with brackets. Just the engine 5-$600 if it is in working order.
Jurassic-1 is offline   Reply With Quote
Old 08-13-2015, 09:10 AM   #4
engineer_gregh
engineer_gregh's Avatar
Re: 1971 big block
Typically $500-$700 here. Expensive to rebuild and the heads do not flow well. My 71 truck 402 is running 65-66 Impala 396 325HP heads. I'm running 1969 375HP heads on my roller 454 in a the 72 Chevelle.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 08-13-2015, 09:55 AM   #5
cooperhw
cooperhw's Avatar
Re: 1971 big block
I believe it would go for between 500 and 800 depending on if it can be made to run when they come look at it.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 10-17-2015, 05:21 PM   #6
Salpezz
Do you still have this engine?
Salpezz is offline   Reply With Quote
