Old 11-02-2015, 02:08 PM   #1
michaely31
trans grind into reverse
any ideas why my manual transmission on my 72 gmc is grinding when going into reverse
fluid levels?
clutch?
operator error (I haven't had this problem before)?
thanks
-Michael
michaely31 is offline   Reply With Quote
Old 11-02-2015, 02:13 PM   #2
michael bustamante
michael bustamante's Avatar
Re: trans grind into reverse
if i dont push my clutch into the floor panel, my reverse will grind too
1967custom
michael bustamante is offline   Reply With Quote
Old 11-02-2015, 02:37 PM   #3
joecaruso
joecaruso's Avatar
My transmission does the same thing. My clutch is also in adjustment, so I've found to just double clutch into reverse and it does not grind. I know probably not the best solution but the time being thats what works for me.
joecaruso is offline   Reply With Quote
Old 11-02-2015, 03:13 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
There's a shift pattern that helps too, but it's been so long since I had my 3 speed.
Maybe 1st, then R? Meaning with the clutch in, shift to 1st first, then into R and it helps.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-02-2015, 03:16 PM   #5
michaely31
thanks, I never considered that
Old 11-02-2015, 03:19 PM   #6
sstone69
sstone69's Avatar
I shift mine into second and then reverse, stopped the grinding
"You gonna pull them pistols or whistle dixie ?"
sstone69 is offline   Reply With Quote
Old 11-02-2015, 03:24 PM   #7
joecaruso
joecaruso's Avatar
Yes that is what I meant to say too. Do not know why I said I double clutch. I do in fact go into first then up to reverse in on motion which eliminates any grinding. I was told by someone along the line that this was due to a non synchronized reverse gear, but whether or not that is the cause someone else would have to confirm.
Old 11-02-2015, 03:25 PM   #8
67ChevyRedneck
I drove with my 3 spd for about 6 years before I put a 700R in, around 2002? So, I'm a little fuzzy on the shift combo!
Try 'em all and see if any work for you.
Jesse James
Project "On a Dime"
Old 11-02-2015, 07:42 PM   #9
Bigdav160
Bigdav160's Avatar
Reverse is not synchronized in these old transmissions.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-04-2015, 01:29 PM   #10
Baddflash
I find I just need to hold the clutch in for a few seconds before I shove it in reverse and no grinding.
Baddflash is offline   Reply With Quote
Old 11-04-2015, 08:39 PM   #11
volksworld
the clutch is not disengaging completely and allowing the input shaft to spin...a syncronized gear is much more forgiving to this condition...the clutch might need to be adjusted,there could be oil or grease on the disc causing it to stick to the flywheel and/or pressure plate,a bad pressure plate not releasing evenly,a disc with a piece of friction material hanging off and dragging, or a worn or dry input shaft bushing in the back of the crankshaft could all cause this...sticking it in a syncro gear to get it to stop spinning then quick stuffing it into reverse will make it driveable but you're not doing your tranny any favors
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
clutch, reverse, transmission grind
