Old 11-16-2015, 09:50 AM   #1
Vandals909
Front suspension member
I'm currently rebuilding the front end on my 71 and noticed the bottom lip on the front suspension member looks like the prior owner hit something and the lip is bent.
Is there a difference between the years? Is one year better than the other?
Vandals909 is offline   Reply With Quote
Old 11-16-2015, 01:54 PM   #2
SCOTI
SCOTI's Avatar
Re: Front suspension member
There are minor variations between the year models but the crossmembers are interchangeable.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-17-2015, 01:01 AM   #3
Vandals909
Can you elaborate? My truck is a 71, should I get only a 71 front member to make sure I do not need to do any mods?
Thanks!!!!
Old 11-17-2015, 10:44 AM   #4
SCOTI
SCOTI's Avatar
Thanks!!!!
Brake line tabs varied through the years. If you wan't a direct plug & play set-up, stick w/a 71-72 x-member. If the brake lines have changed & don't use the OE tabs, other year x-members can be used.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-17-2015, 11:08 AM   #5
Vandals909
Thank you
