Re: Let's Build A 1 Ton Crew Cab 4x4
true. i had removed the heavy bumpers so it was compared to only putting in half the fuel weight. i still plan to put in a 50 bed tank and install a short bed by moving spring perches.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
So I made a little bit of progress over the weekend. In total about 6 hours worth of work. A few on Friday and then some last night.
I need to sell the TH400 ![]() This 350TBI is in good shape & will have to do for a bit until I can find a good running 6.5 TD or rebuild the one I am picking up soon. Found out not only was the headgasket on the DS leaking at the rear but the passenger side had blowby as well across cylinder 4 & 6. I will be taking the heads to be checked. They were rebuilt heads, they had the heat sensors on them. Engine looks like a remanned one, rear main seal was even leak free. ![]() I got the front hangars off the 2wd frame and started working on the sway bar and the front xmember.. Getting there. ![]() Started stripping down the Dana 60 as well. ![]() I need to order some parts. Mainly the parts needed to attach dana 60 to front end & longer U bolts for my 4" lift springs. Still need to find some Dana 60 locking hubs. I am trying to avoid getting real spendy on this build. As well as clutch pedals for hydraulic clutch and hydroboost brakes. Then I need to find a reasonably priced 32 spline transfer case!
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF 2020 1500 Silverado 3.0 Babymax 2002 2500 Silverado- 6.6/ Allison 2010 CTS V- The "NastyBuzzard" 1979 Trans Am - Eventually getting 6.0/T56 swap with boost |
