Old 02-14-2016, 06:07 PM   #1
Oliver.G
Unhappy Hazard Switch broke off!
Hello,
I have a 1969 GMC 2wd 2500
The red hazard switch sticking out of the steering column broke clean off. I lost the piece so there's no hope in super gluing. I found another thread on this that mentioned a reproduction that includes the whole wiring assembly and it would cost me around $60 to get it to Canada. Yikes. Are there any other options for me to fix the flasher. I am ok if it does not look original. I just want to have it operational again.
There is picture of the part on this thread if you scroll down,
http://67-72chevytrucks.com/vboard/s...d.php?t=464846
Oliver.G is offline   Reply With Quote
Old 02-14-2016, 06:31 PM   #2
70cst
70cst's Avatar
Re: Hazard Switch broke off!
I did search through Classic Heartbeat and GMCPaul's. No Luck
If you became a Premium Member you could post a Want To Buy - and there is a chance someone would give you one for free.
Another option is find a Salvage Yard that still has these trucks for parts.
Good Luck.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-14-2016, 07:47 PM   #3
cleanfreak
cleanfreak's Avatar
Try your local parts store , still available from standard , part number tw24 , shouldn't be that hard to get.
cleanfreak is offline   Reply With Quote
Old 02-14-2016, 08:14 PM   #4
hugger6933
A turn signal switch is around $35 bucks The flasher [hazard] thingy is on the side of the turn signal switch you your gonna have to change it. UNLESS, you go to a pull it type yard or know somebody that has some old stuff laying around, the later model trucks and cars from the general had a black knob with a plastic bezel and a spring and screw. Maybe you could take one of those off a newer column and get a longer screw if needed at the hardware store and screw the newer type knob on to the older type switch. Does that make any sense to you? Jim
hugger6933 is offline   Reply With Quote
Old 02-14-2016, 08:17 PM   #5
davepl
davepl's Avatar
I grabbed one off eBay I think (because eBay has pictures - hello Vendors) cheap when I broke mine. They're still pretty much a commodity item, probably because they're so easy to break off!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-15-2016, 12:22 PM   #6
Oliver.G
All right. I'll call the parts store and have a look on ebay for an original. If not I'll justhave to pick up the whole turn signal assembly. Thank you everyone
hazards, interior
