Old 03-02-2016, 09:16 PM   #1
Dino25Mumin
Dino25Mumin's Avatar
Truck dies when in gear
Okay I have a 68 stepside with a 350 with a mild cam and a 700r4. My problem is when I put it in gear (drive or reverse) and try to accelerate it dies, but when it's in park or neutral it revs up perfectly fine and everything. but when I shift it into reverse or drive it'll idle perfectly fine, however as soon as I attempt to accelerate it turns off.
Anyone know what could be causing it?
Dino25Mumin is offline   Reply With Quote
Old 03-02-2016, 10:14 PM   #2
geezer#99
geezer#99's Avatar
Re: Truck dies when in gear
Lack of initial timing and/or inadequate accelerator pump shot.
Old 03-03-2016, 01:43 AM   #3
67chevy_hotrod
67chevy_hotrod's Avatar
I second that! Make sure your timing is dialed in. Also what carb? What does it idle at in park?
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 03-03-2016, 10:24 PM   #4
Boyd67
Boyd67's Avatar
I remember my dad's chevelle doing the same thing. I asked my dad about it because he messes with 700r4's and his chevelle was doing the same thing. He said the guy who built the transmission had something backwards in the transmission. He isn't sure what it was but the guy swapped around and it run fine ever since.
Boyd67 is offline   Reply With Quote
Old 03-03-2016, 10:27 PM   #5
Dino25Mumin
I had someone come out and do the timing and I'm running a edelbrock 1406.
Could loose valve springs be a problem as well?
Old 03-03-2016, 10:31 PM   #6
1955 mancave
1955 mancave's Avatar
if your converter is bad that will cause it to die
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 03-03-2016, 11:21 PM   #7
Boyd67
Boyd67's Avatar
My dad and I talked about that as a possibility too. I wouldn't think it was engine related if it's fine in park and neutral.
Old 03-03-2016, 11:23 PM   #8
Dino25Mumin
That's what confused me so much.
Old 03-03-2016, 11:24 PM   #9
2manycars2littletime
Lock-up torque converter not disengaging?
Keep your head up...and your stick on the ice.
2manycars2littletime is offline   Reply With Quote
Old 03-03-2016, 11:54 PM   #10
geezer#99
geezer#99's Avatar
If you suspect the tranny or lockup just 'hot brake' it!
Bring the rpm's up slightly (about 1000 rpm) with your foot on the brake and slip it into gear. Feather the throttle with the brake on to keep it running. Then slowly decrease the rpm so it will idle in gear. If it keeps running it's not tranny related. If it dies it's timing related.
Old 03-03-2016, 11:56 PM   #11
Dino25Mumin
I'll have to try that! Thank you
350, 700r4, acceleration trouble, sbc, stalls
