Old 05-09-2016, 06:14 AM   #101
bruceman1968
bruceman1968's Avatar
Re: GMC and Chevrolet VIN and Model Number Decoders with pics.
Hi ChevyCheyenne71,
On your model number, the 14 is the code for Axel to Cab dimension. I equated that to wheelbase because wheelbase length provides more useful information than a Axel to Cab dimension does. Also to save space and still include all most all of the trucks found on this website, the trucks over 1 ton, or over 133" WB were left off. The decoders only cover light duty trucks, 133" WB or less. In your case the 14 is a Axel to Cab dimension of 84" to 89". Which equates to a wheelbase of 157" Hope that helps and welcome to the forum. Looking forward to seeing more of your truck. Nice looking Dually you have there.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 05-09-2016, 04:40 PM   #102
ChevyCheyenne71
Thank you guys for your answer i understand now
ChevyCheyenne71 is offline   Reply With Quote
Old 08-02-2016, 05:51 PM   #103
Okiefromwatonga
This is by far the easiest vin decoder to use and best looking one i have ran into in my many vin decoder searches. I have a small problem though. The truck i. Trying to decode is a GMC 5500 (Same as a chevy C50) and its vin is different than what are pictured. Its vin is CE50V-A102079
Okiefromwatonga is offline   Reply With Quote
Old 08-02-2016, 07:05 PM   #104
bruceman1968
My GMC reference materials are packed up right now. (I'm in the middle of a move). But let me see if I can get this off the top of my head.
CE50V-A102079
C = 2wd
E = V-8
5 = 2 Ton
0V = Cab & Chassis
- = Space reserved for special designation
A = Atlanta assembly plant
1 = 1971
02097 = Unique serial number
Thanks for the complement on the decoders.
Old 08-02-2016, 08:25 PM   #105
kwmech
So one of my trucks is also a GMC 1 ton with the 157'' wheelbase (used to be a class B MH) Pretty sure the wheelbase code is 64, that is what is says on the glove box anyways as the model-- CE364OV -- vin: CE3OV ZA 2....
Old 08-02-2016, 08:36 PM   #106
sherm6413
my vin doesn't really match up ... {I have CE149S894367------supposed to be original title to factory swb chev 1969 fleetside ......
sherm6413 is offline   Reply With Quote
Old 08-03-2016, 12:15 AM   #107
bruceman1968
kwmech, you got it right.
Model number
CE364OV
C = 2wd
E = V-8
3 = 1 Ton
64 = 157" Wheelbase
OV = Cab & Chassis
VIN
CE3OVZA2....
C = 2wd
E = V-8
3 = 1 Ton
OV = Cab & Chassis
Z = Fremont assembly
A = 1969
2.... = Unique Serial number, Starts at 10001
Old 08-03-2016, 12:16 AM   #108
bruceman1968
sherm, yours is correct for a 1969 Chevy 1/2 Ton.
C = 2wd
E = V-8
1 = 1/2 Ton
4 = pickup
9 = 1969
S = St. Louis assembly plant
894367 = Unique serial number, starts at 800001. (All Chevy light duty trucks started with 800001 in 1969)
This decoder will work for yours. I left off the starting number for 1969 (800001) and 1971 (600001) on this decoder. All other years 67, 68, 70, and 72 started with 100001. (Chevrolet light duty only)
Old 08-03-2016, 12:47 AM   #109
kwmech
Model number
CE364OV
C = 2wd
E = V-8
3 = 1 Ton
64 = 157" Wheelbase
OV = Cab & Chassis
VIN
CE3OVZA2....
C = 2wd
E = V-8
3 = 1 Ton
OV = Cab & Chassis
A = 1969
What I was trying to pass on is that the 157'' wheel base has the 64 designation not mentioned in your data, unless I missed it in the past 5 pages
Old 08-03-2016, 07:25 AM   #110
bruceman1968
Quote from post #1
"We intentionally tailored the decoders to fit the trucks most commonly found on this website"
You didn't miss it. We intentionally left it off as well as many other codes that could be found on Chevy or GMC trucks, but are not common on this website. If we included them all the font would be to small or the decoder would be to large to be a quick and easy resource for the trucks most commonly found on this website.
Old 08-04-2016, 10:09 AM   #111
BILT4ME
Hi Bruceman1968!
This is a GREAT decoder!
We just picked up a 1970 GMC K20 for my son's project and I see in the VIN decoder that apparently this truck was a Cab/Chassis. I was wondering if you could help with the "F" designation so I can determine what it was originally. the frame number and the pillar tag match. The truck has been repainted, but it has a Chevrolet tailgate on a GMC, and now that I see this, there is a distinct possibility that it was used as something else before we got it. We do know that it was used to tow heavy construction equipment for most of its life.
KE203-FZ64735
MODEL KE25903
3/4T
4X4
350 V8
4 SPEED
HD F/R SPRINGS
RADIO
AMMETER, OIL GAUGE
A/C
PS
(NO PB)
7.50-16.5 WHEELS (SPLIT RIMS)
HD BATTERY
MED BLUE
L/R OUTSIDE MIRRORS
TINTED GLASS
BLUE VINYL TRIM
LOCKING FRONT HUBS
I'm mostly curious about the
"F" designation....Flatbed?
Thanks!
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 08-04-2016, 11:46 AM   #112
bruceman1968
Happy to help. Here is the correct VIN decoder for your 1970 GMC. The F is for the Flint assembly plant.
KE203-FZ64735
K = 4wd
E = V-8
2= 3/4Ton
03 = Cab & Chassis
- = Space reserved for special Designation
F = Flint Assembly plant
Z = 1970
64735 = unique serial number, starts at 50001 in 1970
And here is the correct model number decoder for your truck. As you can see, the 03 designates it as a cab and chassis.
KE25903
K = 4wd
E = V-8
2 = 3/4Ton
59 = 127' Wheelbase
03 = Cab & Chassis
Old 08-04-2016, 11:56 AM   #113
BILT4ME
Thanks bruceman1968!
I was hung up on the FZ thinking the Z was for Fremont. I was mentally bypassing the dash, but now I see the Z is for 1970.
Is the "Fenderside" a pickup bed? And a Cab and Chassis something that maybe would have been given a flatbed somewhere later after delivery? Because right now, it has a pickup bed on it that APPEARS to have the same under color of paint as the rest of the truck, but since it has a Chevy tailgate..........who knows.
It does have the 127" wheelbase.
There is evidence of a plow having been attached to the front, so it very well could have been a plow truck with a sand bed on it or a water/oil tank.
Thanks again!
1970 GMC K2500
Old 08-04-2016, 12:20 PM   #114
bruceman1968
Fenderside is GMC's name for a stepside bed. Your truck was originally built as a cab & chassis, with no bed on it. It could have had a flat bed added to it at the dealership or anytime after that.
Old 08-07-2016, 09:28 AM   #115
bruceman1968
CE50V-A102079
C = 2wd
E = V-8
5 = 2 Ton
0V = Cab & Chassis
1 = 1971
Okie, SS Tim called me yesterday with some concerns about the decode I did on your truck. This morning I went through your previous posts and found the pictures of your SPID. From the pics of your SPID, I know I made a mistake on the decode. Often on SPIDs, the unique serial number was printed at a different time from the first half of the VIN and it shows with different Font and alignment. This is clearly the case on your SPID.
Your unique serial number is clearly 102079 which would make the A the model year. 1969 in this case. Sorry for any confusion my incorrect decode might of caused in relation to the year of your truck. It is a 1969.
Old 08-07-2016, 11:34 AM   #116
Okiefromwatonga
No worries, im not too worried about it and 99.9% of any parts are the same. Luckily I havent started anything so no harm no foul
Old 08-20-2016, 11:31 AM   #117
kehstr
kehstr's Avatar
subscribed
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 11-23-2016, 02:02 AM   #118
aanthonys210
Hello all seems to me that my vin numbers can't be matched can someone please HELP!!!!
CE134-S110925
Got it
Thank you
C- 2wheel drive conv cab
E- V-8 gas
1- 1/2 ton
34- wide side
S- St Louis
1- 1971
10925- Starts at 10001 (1971)
aanthonys210 is offline   Reply With Quote
Old 11-23-2016, 02:18 AM   #119
SS Tim
SS Tim's Avatar
CE134-S110925
Its a 71 GMC VIN number!
C Conventional 4x2
E V8 gas engine
1 1/2 ton
34 wideside bed
S St.Louis assembly plant
1 1971 model year
10925 serial/sequence number, started at 10001
SS Tim is offline   Reply With Quote
Old 12-11-2016, 12:50 PM   #120
iriereggaeman
iriereggaeman's Avatar
Thanks bruceman1968! Very cool indeed. I was deciphering my Model number, using http://www.caaarguide.com/sub1/id442.html which had my burban listed as a 3-door wagon with liftgate. The burban has the barn doors (aka cargo doors?), so I was wondering someone had done a swap before getting to me. Your 67-72 K10 decoder ring produced this:
VIN = CKE162F145864
C = Chevy
K = 4WD
E = V-8
1 = 1/2 ton
6 = Suburban
2 = 1972
F = Built in Flint Michigan
145864 serial number
Model KE10916
K = 4WD
E = V-8
1 = 1/2 ton
09 = 127" Longbed (Wheelbase Length)
16 = Suburban/Cargo doors
which seems much more accurate! Thanks again!!
iriereggaeman is offline   Reply With Quote
Old 12-11-2016, 02:32 PM   #121
bruceman1968
iriereggaeman, Glad the decoders helped you out. You have a very nicely equipped suburban there. Welcome to the forum.
Old 03-05-2017, 12:04 PM   #122
Kevin McPherson
Kevin McPherson's Avatar
I am having trouble decoding my 1967 1/2 ton 4x4 suburban. Can you help? It doesn't seem to follow any of the rules. I only have a 12 digit VIN code, and the DMV tells me it should have 14.
Last edited by Kevin McPherson; 03-05-2017 at 12:14 PM. Reason: Trying to add picture
Kevin McPherson is offline   Reply With Quote
Old 03-05-2017, 12:18 PM   #123
Kevin McPherson
This is the original options list
Old 03-05-2017, 12:39 PM   #124
dmjlambert
dmjlambert's Avatar
It follows the rules in the picture bruceman1968 posted at 08-02-2016, 10:16 PM above, post #108
According to your VIN and the decoder, you have a 4wd 8-cylinder 1/2-ton Suburban 1967 Fremont-built with 6 digit serial number.
That is 12 characters. DMV is mistaken (first time that has happened, probably :-).
Thanks for finding this thread and bringing it back to the top. It is interesting and informative and I'm going to bookmark it.
dmjlambert is online now   Reply With Quote
Old 03-05-2017, 02:03 PM   #125
SS Tim
SS Tim's Avatar
Kevin, While a 67 GMC could have a 14 digit VIN, the 12 digit VIN on your 67 Chevrolet Suburban is correct and clearly so !
As was indicated it breaks down as,
K Conventional Cab 4x4
E V-8 engine (base 283 in your case)
1 10 Series 1/2 ton
6 Suburban
7 1967 model year
Z Fremont California assembly plant
156477 Unit serial number
Additional SPID coded information
Paint code 451 is Medium Blue Poly (metallic) code 506, applied as a two-tone with a code 526 Ivory roof.
Model number KE10916 confirms it to be a 4x4 V-8 1/2 ton Suburban with tailgate.
