Old 07-23-2013, 04:14 AM   #201
kikkegek
kikkegek's Avatar
Re: Starting to start starting a C4 conversion on my 84 SWB GMC
sweet build.... (Y)
kikkegek is offline   Reply With Quote
Old 07-23-2013, 08:59 AM   #202
trout
Nice build glade to see it on the ground was following back when you fist started
Edited by staff
trout is offline   Reply With Quote
Old 08-27-2013, 05:38 PM   #203
Tagg33
Tagg33's Avatar
Last Saturday I entered my truck in a show at Lincoln Tech College here in Denver, CO. Last time they had Hot Rod TV filming but no such luck this time. It was still fun tho! This was my first show with the truck aired out. Still a lot to do on the truck before I would consider it show worthy but I'm glad to have the Accuair system on with my EDC (engine driven compressor). I hardlined with 3/8" copper-nickel hydraulic line. I'm going to redo a couple of the lines for cleaner bends and I still need to polish it all.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 10-21-2014, 01:25 PM   #204
ccreddell
ccreddell's Avatar
Any updates on this?
ccreddell is offline   Reply With Quote
Old 04-24-2015, 11:07 AM   #205
Tagg33
Tagg33's Avatar
I finally got some things done I can post. I've been wanting to put hood struts on for quite awhile now. I considered buying a kit but that's not as much fun as figuring it out yourself.
I was able to use the original brackets that mount to the hood and made the stand-offs for the bottom mount. This is completely bolt on at this point. Which wouldn't normally be so easy but my inner fender wells are cut out, giving me access to put a bolt in there.
Ryan
Old 06-16-2015, 10:08 AM   #206
Tagg33
Tagg33's Avatar
Got my rear fenders done last weekend. My dad visited for the weekend and gave me the inspiration to get it done. This was 2 solid days of fab, more than I ever expected. I had already cut the inner bed sides for tire clearance but wanted to start the project with welding in mini-tubs to fill in the cut area. Colorado seems to encourage rust a little faster than I'm used to from AZ so I was extra careful to prime the back sides and edges of everything before they got welded in. This copper weld-thru primer is really cool. So it ended up being 3 pieces per side; mini-tub, mounting flange, and full trailer fender to get the width I needed. I also cut the battery box off the frame and re-welded it upright. I was able to clean-up/hide my air compressor relay wires and redo my battery cables. For part 2 of this project I will connect the front and back of the new fenders to the existing bed floor with flat pieces of sheet metal from tandem fenders I bought. I'm keeping the middle of the floor open so you can always see the Corvette IRS. I'm also planning to install sheet metal vertically on the bed sides to finish it off.
Ryan
Old 06-16-2015, 10:11 AM   #207
Tagg33
Tagg33's Avatar
here's more
Ryan
Old 06-16-2015, 10:13 AM   #208
Tagg33
Tagg33's Avatar
and finally
Ryan
Old 06-16-2015, 01:21 PM   #209
kikkegek
kikkegek's Avatar
nice job man!
Old 06-16-2015, 05:17 PM   #210
BBM3
BBM3's Avatar
Very impressive! 6 years and still going.
Please give us a heads up next time you take your truck to a show I would love to see it in person.
Keep up the great work.
-BB
1975 Chevy K-10 (Project)
2014 Mustang GT 6spd MT, Track Package, Recaro's (Toy)
2006 Avalon (Inherited, Daily Driver)
BBM3 is offline   Reply With Quote
Old 06-16-2015, 06:15 PM   #211
Tagg33
Tagg33's Avatar
Originally Posted by BBM3 View Post
Please give us a heads up next time you take your truck to a show I would love to see it in person.-BB
Thanks BBM3, I will possibly show it at the Budweiser Super Custom Car Show in Denver Aug 9th.
Ryan
Old 06-16-2015, 08:16 PM   #212
BBM3
BBM3's Avatar
I have subscribed. Keep us posted.
Old 02-20-2016, 11:25 AM   #213
Tagg33
Tagg33's Avatar
Working on front inner fenders. Got the passenger side done recently. Last weekend I wanted to start on the driver side and realized my hood release cable was in the way so I moved it and created an new billet alum handle for it. Now I can get to work on this inner fender.
Ryan
Old 02-20-2016, 11:30 AM   #214
Tagg33
Tagg33's Avatar
Finished off my exhaust pipes and tip. I've had this piece for over 3 years just never put it on because I was working on other stuff in the area.
Ryan
Old 08-10-2016, 10:09 AM   #215
Tagg33
Tagg33's Avatar
Some progress: the bed area and rear suspension are all painted. I tinted Raptor liner with the same silver as the rest of the frame. The Corvette suspension pieces are a charcoal metallic. The inner bed sides are aluminum panels I made out of transit fenders.
The front inner fenders are done and bolted on too. Engine bay is finally finished.
Ryan
Old 08-10-2016, 10:49 AM   #216
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-10-2016, 02:24 PM   #217
kikkegek
kikkegek's Avatar
good lord! that is one super sick build...respect man!
But where did the exhaust go? cant figure that out.
If I go from picture t picture, then the gastank seems to be in the place where the exhaust runs under the truck
Old 08-10-2016, 05:53 PM   #218
Tagg33
Tagg33's Avatar
Thanks kikkegek! The exhaust runs under the Corvette differential and under the gas tank. It exits right under the license plate. Here is an upside down pic of the exhaust in primer.
Ryan
Old 08-10-2016, 05:57 PM   #219
kikkegek
kikkegek's Avatar
`nice! car looks frekking awesome
Old 08-11-2016, 10:26 AM   #220
Tagg33
Tagg33's Avatar
Took a couple pics with better lighting. The bed is complete, just need to touch up some red paint here and there on the truck.
Ryan
Old 08-11-2016, 11:03 AM   #221
kikkegek
kikkegek's Avatar
that rear axle is so badass
Old 08-12-2016, 03:41 AM   #222
LT7A
Nice work Tag33! I'm a fan of all kinds of these trucks. Mine are the kind that show their 'character' from living a truck's life . But I can certainly appreciate the detail that goes into a truck like yours. The graphics have grown on me for sure and somehow go great with the wheels. I wouldn't recommend changing a thing with those. It ties it back to its history nicely.
Old 08-12-2016, 04:29 AM   #223
Desert1957
Desert1957's Avatar
Beautiful work, nice attention to detail.
Desert
Desert1957 is offline   Reply With Quote
Old 11-14-2016, 06:14 PM   #224
Tagg33
Tagg33's Avatar
Just posted the truck for sale on this forum and ebay. Please check it out and tell your friends! http://r.ebay.com/lVNYHU
Ryan
