![]() Join Date: Mar 2014
Reinstalling Rear Pinion Gear.. How to..?
Doing a quick cleaning and painting of my rear end housing, new axle bearings and seals but keeping the same bearings on my ring gear and pinion.
Same nut and washer, how do I put the pinion back in properly? What torque? What spinning torque?
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
![]() Join Date: Mar 2003
Re: Reinstalling Rear Pinion Gear.. How to..?
Which rear axle
I personaly would opt for a new crush sleeve , pinion Nut and bearings , I would think with using your old crush sleeve it would be almost impossable to set the correct Pre load on the bearing ......if you go to tight premature bearing wear will occur quickly ,If to loose same will occur at a slower pace .You will Know quickly as soon as you drive you while Here a Whine or drone noise
![]() Join Date: Jun 2005
You need to replace the crush sleeve and pinion nut at the very least. They are designed for one-time use.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Tags |
differential, pinion, rear end, torque |
