09-01-2016, 09:01 PM | #51 |
Re: 1972 Medium Blue Highlander Blazer Resto
Nice one Pete ! I'll be watching
09-01-2016, 09:58 PM | #52 |
I'm trying....
This is a great service Pete. Let me add my Kudos and Thanks.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
09-04-2016, 12:53 PM | #53 |
Carpe manana
Thanks guys for the good words and for following along. Here are some additional pics - sorry for the poor handwriting
09-04-2016, 12:54 PM | #54 |
Carpe manana
Harness grounds...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 09-04-2016 at 01:16 PM. |
09-04-2016, 12:57 PM | #55 |
Carpe manana
Hoses (upper rad is from my K1500 - OEM hose was on the Blazer but the p/n was too faded to photo)
09-04-2016, 01:00 PM | #56 |
Carpe manana
Zip ties and heater hose bracket at RH fender
09-04-2016, 01:03 PM | #57 |
Carpe manana
Steering damper at tie rod. Factory install for 1972 MY only. Measured from end of tie rod tube itself. Location of gear ratio tag at front differential. Misc other under hood pieces.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 09-04-2016 at 02:36 PM. |
09-04-2016, 01:07 PM | #58 |
Carpe manana
Gas pedal/cowl related...
09-04-2016, 01:08 PM | #59 |
Carpe manana
Wiper arms...
09-04-2016, 04:00 PM | #60 |
Carpe manana
Excavated the build code on the transmission: Y2B 08D . By my reading it's a Cleveland (Y) built TH350 from 1972 (2) February (B) eighth day (08) from the day shift (D). As such, the date fits for the original transmission and helps to support a February 1972 assembly month for the Blazer.
The engine block code is V0207TFJ and breaks down as follows: Flint (V) built in February (02) seventh day (07) 350 cu in for c/k pickup 4bbl application with automatic transmission (TFJ).
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 09-04-2016 at 04:10 PM. Reason: added |
09-04-2016, 07:07 PM | #61 |
Very educational photos you got there Pete.
Thanks for taking the time to lay everything out like that I'll be saving these photos into my notes I think others will be doing the same ... |
09-05-2016, 10:19 AM | #62 |
09-05-2016, 07:46 PM | #63 |
I see another TOTY in the making.
09-23-2016, 03:06 AM | #64 |
following this build
09-25-2016, 07:39 PM | #65 |
Carpe manana
Thanks for following along and all the good words!
Finally able to pull the motor and tranny - will have both rebuilt and reinstalled. I've kept them bolted together and am using the depicted Moto-Feet stand (USA made) with rubber casters to wheel them about the garage. After pulling the Blazer to the concrete pad I realized that my tow hook was flipped the wrong direction - doesn't work as well that way
09-25-2016, 07:44 PM | #66 |
Carpe manana
Here's a summary photo of the clips used to affix the fuel/brake/charcoal can lines to the frame. Also included is an example of the harness clips used along the LH frame rail
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 09-25-2016 at 07:55 PM. |
09-25-2016, 07:53 PM | #67 |
Carpe manana
The re-plated parts turned out well. Here are some examples. I've got the bumpers, trim strips, t-case shift handle and a few other parts in El Paso now for chrome plating.
09-25-2016, 07:54 PM | #68 |
Carpe manana
More
09-25-2016, 07:58 PM | #69 |
Carpe manana
It seems the case that OEM inspection covers for the TH350 during at least the 72 model year were plastic. Here's an example - that removed from my blazer is the same.
09-25-2016, 10:23 PM | #70 |
A guy with a truck
Same on my '72
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-03-2016, 09:10 PM | #71 | |
Project looks awesome! I was wondering if you can send me contact information to the company that did the zinc plating for you. I want to get a couple pieces of my own done. :-) Thanks Eric |
10-03-2016, 11:59 PM | #72 |
Carpe manana
Thanks Eric! PM sent...
10-08-2016, 09:33 PM | #73 |
Carpe manana
Baby steps.
A friend traveling to El Paso was gracious enough to transport some items for chrome plating, which were completed this week. Steve, one of the front bumpers is that from your ochre C30 truck. The rear panel trim and NP205 shift handle turned out nice. Also go the Blazer off to the body shop. Anxious to see what's under the paint.
10-08-2016, 10:32 PM | #74 |
I'm trying....
Looks good Pete. Seems like big steps to me.
10-13-2016, 12:18 PM | #75 |
Looking forward to watching the body work progress. I would love to have this specific color combo, and a highlander to boot. Great choice for a resto.
