10-27-2016, 10:31 AM | #1 |
Best 4" lift for big block V6 GMC and pics?
I have a 68 GMC K20 and I'm looking for the best 4" lift kit for it. My engine weights 860lbs and I want leafs that will hold up to the weight. any suggestions on what kit to get I was looking at the rough country 4" heavy duty lift kit. also any pics of trucks with 4" lift that are k20?
10-27-2016, 10:44 AM | #2 |
Re: Best 4" lift for big block V6 GMC and pics?
Hi, I have a 67 Chevy K-10. A few years ago, around 1996 I changed the 1/2 ton springs for 3/4 ton springs along with shocks. this gave me about 2" of lift. Now many years later I am rebuilding the truck again. It is a driver. The front springs have settled 1/2 inch over time. I carefully measured it out before pulling the engine. I intend to build 3" blocks to go between the rear axle and springs. 3 1/2 inch blocks for the front. Then I will figure out what length of shocks I need. The steering will be another issue to get set up as well. I think it will work. I will use new U-bolts too.
I will get you some detailed pictures as I get deeper into it. |
10-27-2016, 09:17 PM | #3 | |
All about them K’s
At the bottom of this article it explains Why front blocks are bad. http://www.fourwheeler.com/how-to/12...-alternatives/
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 10-27-2016 at 09:23 PM. |
10-27-2016, 11:25 PM | #4 |
I would give Off-road designs a call. I know they will have a solution for you. I will NEVER buy an off the self lift spring again. yes, you do spend a little more for the springs, but its absolutely worth it, if you don't want your truck to ride like a basketball... or a brick on steel wheels....
10-27-2016, 11:44 PM | #5 |
I'm not really that concerned with how it rides as much as the springs not sagging from the weighy of the engine. I live near St Louis and there is a place called stl spring I guess I will give them a call or some other places and just get custom Springs.
10-27-2016, 11:53 PM | #6 |
All about them K’s
In my opinion your better off that way because they can build the springs to your application rather than the opposite.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
Tags |
1968 k20 4x4, gmc, k20 |
