Removing gear lever
Hi guys, I am about to replace the gearbox in my '67 GMC with a Turbo 700R4 and am stuck, I need to remove the gear lever from the transmission and don't know how. I CAN take off the top plate on the gearbox, but there must be a way to remove the stick only. Can anyone help please?
Regards from Down Under: ![]() aussiejohn |
Too Dumb To Know Better
Re: Removing gear lever
Push down on the domed ring and twist. You should be able to pull it right out.
Thank you Sir. I logged on and saw your reply no more than four minutes ago. I went out, followed your advice, and out it came!
I am in your debt. Regards from Down Under. ![]() aussiejohn |
You are welcome.
