Re: Project: 1967 C10 Small Window
Well....this control arm is pretty janked I'd say. Also found out the original front crossmember is bent believe it or not, so I'm using the new-to-me one and it's donor LCA. I cleaned/painted hidden areas and bolted in the crossmember for good. Control arms are waiting their turn at powdercoating.
![]() ...anyone want a bent frame? |
I repainted the calipers and spindles as well as some new rotors. The front end should be ready for assembly when I get the control arms back. This will likely be hidden with my new wheel choice..... "but no one is going to see it" has never been a valid reason for me to not do something!
Tags |
1967, small block, small window, stepside |
