Old 07-21-2015, 07:44 PM   #26
mooseknuckles
mooseknuckles's Avatar
Re: I'm back with another C10 build!!!!!
I'm in....
mooseknuckles is offline   Reply With Quote
Old 07-21-2015, 09:42 PM   #27
joedoh
joedoh's Avatar
lets hear it for the "all season garage"! I bet you have nicer outdoor weather than some of us driveway mechanics though. today was only 84, but at 78% humidity! I look like I took a shower.
nice work so far!
Old 07-21-2015, 11:24 PM   #28
YOLO
Custom Truck Lover!
YOLO's Avatar
nice work so far!
This time of year is monsoon season. Temps run 100-115 and humidity gets higher through out the day. I too am a sweaty man! I stay under an ez up and jump in the pool when I am saturated with sweat. My trusty gallon of water is close and I take many short "time outs."
Being a fireman I am used to being outside and sweating. I am older now and just pace myself. I try not to work on the truck for more than 3 hours this time of year. It is just fun to be at home and tinker.
Squarebody guy
YOLO is offline   Reply With Quote
Old 04-04-2016, 08:09 PM   #29
YOLO
Custom Truck Lover!
YOLO's Avatar
Life has gotten in the way but I am making progress.
mocked the tilt column in to measure for new steering rod.
used stock radiator side mounts, flipped sides, cut them up. I will use a fan shroud.
used CaptinFab adapter plate, AWESOME! Mounted 73-87 2wd steering box.
Squarebody guy
Old 04-04-2016, 08:14 PM   #30
YOLO
Custom Truck Lover!
YOLO's Avatar
more progress.
FJ steel wheels with 235/60/17. Bed is not mounted as mods are easier when off the truck.
No spacers, no rubbing, perfect. I will probably cut more out of the drop springs when all is said and done.
The SBC is from a 90's Corvette. The 70 Camaro motor had a crack in it. We built this new motor from scratch. This is one of the things that set me back.
Serpentine is from 90's Suburban. I will be running A/C, PS, PB, etc. This truck will have all the goodies as I plan to drive it almost every day.
Squarebody guy
Old 04-04-2016, 09:28 PM   #31
Turtleman
Turtleman's Avatar
It's worth the set back in time but it's an advance in all other areas
Good to see your still at it
Turtleman is offline   Reply With Quote
Old 04-04-2016, 10:57 PM   #32
YOLO
Custom Truck Lover!
YOLO's Avatar
Just a heads up the Performance online transmission cross member needed to be modified. I had to chop the mounts that go between the frame and raise it 1.5 inches. The drive shaft angle was bad and the motor was leaning back.
Squarebody guy
Old 04-28-2016, 10:57 PM   #33
YOLO
Custom Truck Lover!
YOLO's Avatar
Got more work done today with my 2 little girls helping me out. They were a big help mounting the gas pedal. Also finished making connection between steering column and gear box thanks to Captain Fab's part. Built a new piece to go around the blazer gas tank so now the bed is sitting in the correct position (I already want to cut the lowered springs because its not low enough). I put my crusty front bumper on. I ordered the cable for the throttle, and need to find the correct steering wheel adapter to use my stock steering wheel.
Name:  2016-04-28 13.38.20.jpg
Name:  2016-04-28 13.38.59.jpg
Name:  2016-04-28 13.40.49.jpg
Name:  2016-04-28 13.45.07.jpg
Name:  2016-04-28 13.45.48.jpg
Squarebody guy
Old 04-29-2016, 07:35 AM   #34
Ta2Don
Ta2Don's Avatar
Awesome plus Parenting done right!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 04-29-2016, 08:13 AM   #35
BFoley
BFoley's Avatar
In for the build...
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 04-29-2016, 10:23 AM   #36
YOLO
Custom Truck Lover!
YOLO's Avatar
I agree. Wish my parents did that for me. Learning this stuff later is life sucks
I also plan on ruffing up the steering column. Too shiny for this truck!
Squarebody guy
Old 04-29-2016, 02:04 PM   #37
olrosa
olrosa's Avatar
Looks great!
olrosa is offline   Reply With Quote
Old 04-29-2016, 04:02 PM   #38
gabbin
gabbin's Avatar
What gallon tank did you use?
gabbin is offline   Reply With Quote
Old 04-29-2016, 04:54 PM   #39
mjh1965
mjh1965's Avatar
The last truck was just amazing. This one looks like a great start. Count me in .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 04-29-2016, 05:01 PM   #40
YOLO
Custom Truck Lover!
YOLO's Avatar
I dont know. I ordered a Blazer tank from Brothers. Comes with the sending unit to use your factory fuel gauge too.
Squarebody guy
Old 04-29-2016, 05:03 PM   #41
YOLO
Custom Truck Lover!
YOLO's Avatar
Thank you. This truck will not be anything like my 63. This truck will be used and abused. I am not painting it. Just going to use it like a truck and drive it to my fire station every shift. Of course it will have all the modern amenities but still look like a crusty, burned up, 64 C10.
Squarebody guy
Old 09-21-2016, 10:52 PM   #42
YOLO
Custom Truck Lover!
YOLO's Avatar
I have been slacking. My buddy Dave at AZ Auto Tech is helping me get "motivated". He ran fuel and brake lines and made power steering hoses for my conversion. He also opened the rear diff and found water. The truck was sitting for 20+ years. All new 373 gears and bigger spline axles. Rear end is basically new. I hope to have this at Dino's Get Together.
Name:  2016-09-21 10.57.23.jpg
Name:  2016-09-21 10.57.35.jpg
Name:  2016-09-21 10.57.51.jpg
Name:  2016-09-21 10.58.20.jpg
Squarebody guy
Old 09-21-2016, 10:53 PM   #43
YOLO
Custom Truck Lover!
YOLO's Avatar
More pictures
Name:  2016-09-21 10.58.55.jpg
Name:  2016-09-21 10.59.09.jpg
Name:  2016-09-21 10.59.23.jpg
Name:  2016-09-21 10.59.36.jpg
Squarebody guy
Old 01-16-2017, 03:52 PM   #44
YOLO
Custom Truck Lover!
YOLO's Avatar
https://youtu.be/CtNTfiEEZbA
Got my 350/350 up and running. Still lots of tuning to do. This should be my new daily driver soon. Next up, install the bed and wood.
Squarebody guy
Old 01-16-2017, 05:21 PM   #45
joesscamaro
What kind of tilt column did you go with?
joesscamaro is offline   Reply With Quote
Old 01-21-2017, 02:14 PM   #46
YOLO
Custom Truck Lover!
YOLO's Avatar
On Ebay. Cost was around $200.
Squarebody guy
Old 01-22-2017, 11:08 AM   #47
rusty76
rusty76's Avatar
Cool build. I'm in.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-25-2017, 07:47 PM   #48
YOLO
Custom Truck Lover!
YOLO's Avatar
More video with walk around. Drove it up and down the street. Brakes need bled, bed installed with new wood, head lights and tail lights, then A/C.
https://youtu.be/-mL7iiA2vp0
Squarebody guy
Old 01-25-2017, 11:38 PM   #49
rvrfoot
You can put a 2 inch block to lower the back some more.
rvrfoot is offline   Reply With Quote
Old 01-26-2017, 12:02 PM   #50
YOLO
Custom Truck Lover!
YOLO's Avatar
Im happy with the back, the tires tuck just a little. The front needs to be lower. These are 18 inch FJ wheels and tires. I will check clearance when I start driving it and see what I can do.
Squarebody guy
