04-17-2017, 09:03 PM | #1 |
License plate mounting
I picked up a rusty tailgate for parts yesterday from Billy(66burban) and in trying to get the license plate bracket off, I noticed it is held on with clutch head bolts. Who sells a bit to remove them?
04-17-2017, 10:15 PM | #2 | |
Re: License plate mounting
Try Harbor Freight, Tractor Supply, Ace and auto parts stores...
Remember: "When seconds count, the Police are only minutes away". Thx, Billy B. |
04-17-2017, 10:24 PM | #3 |
Thanks. The panel is small enough so I can take it with me. Just have to watch the sharp edges
04-18-2017, 12:50 AM | #4 |
60-66 Nut
You might find a clutch head screwdriver at Napa but not at HF, Tractor Supply or Ace Hardware. You might even have to purchase online.
04-18-2017, 09:38 AM | #5 |
Lots of them available on eBay. J
04-18-2017, 09:52 AM | #6 |
http://www.classicindustries.com/pro...ts/cx1531.html
If I recall, I think my local Ace actually had one too. I have a question for you, 65. My 'burb has the bracket for the top of the plate, and 2 holes in the gate for the bottom of the bracket, but I don't think there are captive bolts in those bottom holes -- how does the bottom of the plate fasten down? B Last edited by bpmcgee; 04-18-2017 at 12:13 PM. |
04-18-2017, 04:47 PM | #7 |
it doesn't. It just "hangs" there and vibrates around. My dad drilled two holes that match the license plate through the lower door, and ran 2 carriage bolts from the inside out, and put star washers and acorn nuts on it and the license plate frame. when I get home, I will take a picture of it to show you what it looks like. This way the plate doesn't drop when I lower the tailgate.
04-18-2017, 05:42 PM | #8 | |
04-18-2017, 06:35 PM | #9 |
i used 2 nylon headlight adjustment nuts, with a large headed phillips thru the plate. years later when the nylon dried out and cracked i replaced them with plastic drywall anchors and the same screws.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
04-19-2017, 09:26 AM | #10 |
Drywall anchors is a very clever idea!
B |
04-19-2017, 01:40 PM | #11 |
04-19-2017, 09:34 PM | #12 |
I also use drywall anchors to secure my door scuff plates because a few of the holes are enlarged due to rust.
