03-16-2017, 10:13 AM | #76 | |
Re: 1972 Build thread.
The gears are manufactured to a particular dimension as far as spacing and center line are concerned.....but.....the housings are manufactured with certain ± tolerances as well...which may or may not be the exact same as what the gears are. The last set I put in my 12 bolt...I set the depth to exactly what was marked on the pinion gear......it wasn't anywhere close when I checked the pattern...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
03-16-2017, 12:03 PM | #77 | |
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
03-16-2017, 01:06 PM | #78 | |
72 Chevy K5 CST |
03-16-2017, 02:36 PM | #79 |
Yes ! I've had issues with both Auburn style (cones) and clutch style that come in our Blazers when using synthetics. I'm not a chemist, but I assume it has something to do with the friction modifiers much like the difference between Dextron and F type transmission fluid.
On my Blazer, I used Amsoil synthetic in the transfer case as well as the front Diff, but because the front is just an open diff, I had no issues. What's odd, is that it claims right on the Amsoil tech sheet that their oil is compatible with locking differentials. |
03-16-2017, 03:06 PM | #80 | |
04-22-2017, 08:07 PM | #81 |
Hi,
I finally got some time to myself in the garage. Please take a look at the patterns on my gears, im looking for second opinions... should i run them or do some more shim work? Pics of the 12 bolt
Full top blazer or bust.... Last edited by Spf79; 04-23-2017 at 01:59 AM. |
04-22-2017, 08:12 PM | #82 |
... and the dana 44
Full top blazer or bust.... |
04-22-2017, 10:41 PM | #83 |
Pattern on both look perfect to me.
72 Chevy K5 CST |
04-23-2017, 01:38 AM | #84 |
Thanks for looking, the 12 bolt set up really easy... the dana on the other hand took 5 or 6 attempts.
I feel good about the contact patterns, i just wanted some other opinions. Thank you again!
11-12-2017, 03:10 PM | #85 |
It has been a busy summer with the kids and work, not much done on the blazer. Over the last month or so I have been able to get back on the project a bit. I am hoping for a rolling frame with drive train by Christmas.
Here are some pics... five at a time.
Full top blazer or bust.... Last edited by Spf79; 11-12-2017 at 03:24 PM. |
11-12-2017, 03:23 PM | #86 |
More pics.
I got the necks on the gas tanks switched out. Needs some paint. My 12 bolt is done, I apparently needed more help with my dana 44, so that is at a buddies house. Hope to finish that up in a week with some more guidance than what I was getting off of Youtube I got springs under the frame last night. Starting the motor project this month.
11-12-2017, 04:25 PM | #87 |
Carpe manana
Nice work. Thanks for the update.
11-12-2017, 10:50 PM | #88 |
Thank you sir! That means a lot coming from you.
I have been following your highlander build. It is amazing!!!
11-23-2017, 03:28 AM | #89 |
Thanksgiving week is always slow at work, so I got some time to finish up my dana. Apparently I had it all messed up & I got educated... always good to have friends that know things.
I was able to have my father inlaw help me move my rear end onto some jack stands and get my front axle on the saw horses. I got my knuckles on tonight, and fitted the spindles. I need to bolt the spindles and caliper plates on. Hope to get the front end under the frame this weekend. Rear end next week. I am waiting on my tie rod and rear end u-bolt plates to get back from the powder coater Monday. Happy face!!!, I got my rear end sway bar and front pumpkin cover today.
11-25-2017, 11:05 PM | #90 |
Finished the front axle tonight. Just waiting on the tie rod to get back from the powder coater. Hoping to get the front axle under the frame tomorrow.
11-26-2017, 03:41 AM | #91 |
Very nice - where did you get the new 6 lug slot rims? Been looking for a used set for awhile - may just need to get new ones instead.
11-26-2017, 04:34 AM | #92 | |
I was in the same boat with the slotted mags, they are stinking hard to find in good shape. Seemed that anything I found in the $500 range was going to need a major polishing job.. I finally found these. I got them off of Amazon for $640. The wheels are a US mags, u101 Indy wheel. Mine are 15x10, with 3.5 back spacing. http://us-mags.com/indy-u101-truck-w-5493.htm. They even have a pic of a Blazer on their website, lol - sold! I think Summit has them as well. I would assume that your local tire guy can get them. I had a mom and pop shop close to my house mount and balance mine. Note, they had to use a mag machine to put the tires one, one fella had to stand on the tire bead while the other guy ran the machine. They can't use a regular tire machine, because it will catch the lip of the wheel and make bad sounds. I used balancing beads as well so I did not have to deal with sticky lead weights. The wheels appear to be of good quality, at this point. Hopefully they run out smooth. Here is the pic of the Blazer off of their website.
11-28-2017, 01:16 AM | #93 |
I had a buddy come by and help me get the axles under the frame tonight. Everything needs to be tightened... and I need to loosen the spring bolts and grease the bushings... hoping it settles out easily. I'm still waiting on my rear spring plates so I had to improvise the rear u-bolts until I get the plates. You have to take help when you can get it. This feels good, starting to look like a Blazer.
12-07-2017, 04:23 AM | #94 |
1st of five 5125 Bilstien shocks showed up today... they were all due today.
The poor UPS guy looked like a train wreck... and I gave up trying to turn the two pics. I did decide to go without the boots, and with them upside down from the traditional mounting style. Apparently the 5125 allows you to run them either way. I thought it was a cleaner look in my opinion. Also, since I am not running boots I figured it would help keep the seal clear from debris. Now I impatiently wait for the rest to show up. I am also waiting on my motor to come back from the machine shop. Yes!!! I hope to see it in another week or two. Funny item I ran into, more of an FYI. If you run the front 1-1/4" tie rod from Offroad Design without their add-a-leaf in the front it will hit the bottom of the leaf springs. Oh! And if you run the stock height steering arm it will hit the tie rod at full lock. So now I have to get rid of my drop pitmant arm, and buy a raised steering arm.
Full top blazer or bust.... Last edited by Spf79; 12-08-2017 at 01:26 AM. |
12-08-2017, 01:25 AM | #95 |
2nd shock showed up tonight. Supposedly the rest tomorrow.
Happy dance!! My cam and rocker arms showed up a day early!! Happy dance #2, my youngest got his next stripe, almost a purple belt!! Now... onto some homework with the boys tonight and then bed time... and then garage time. Hopefully I can get the rear shocks bolted in.
12-08-2017, 10:03 AM | #96 |
Could you post a few more pictures of your front sway bar ? Do you know who manufactured it?
Also, how close is the rear sway bar from the diff cover? I'm asking because I would like to add one to my Blazer, but I only have around 5 inches between my diff cover and custom fuel tank. I'm also curious as to what that bracket is I circled in the picture. Thanks !! Last edited by hemi43; 12-08-2017 at 10:42 AM. |
12-08-2017, 03:14 PM | #97 | |
12-08-2017, 04:19 PM | #98 |
where did you get your bilsteins from and for what year truck/blazer? Thanks
12-08-2017, 05:31 PM | #99 | |
I went out this morning and bought an original 73 up front anti-sway bar from Bill's trucks which is just a few minutes from here. For some odd reason, I had a urethane bushing kit for it here which was a bonus. I will have to fab some front mounting pads, because I'm told the first Gen Blazers never came with front anti-sway bars. While under the truck, I decided to buy new leaf springs also, and opted for the Tuff Country EZ-Ride with a 2"lift. I like the idea of having the rear bar face forwards so I'll look into the one you used, because I may have fitment issues mounting rearwards. My exhaust pipes are in the way. Thanks for the info !! Edit; I just checked the price for the Addco 202 here in Canada. $334.00 VS $186.00 at Jeg's !! FFS, I get fed up living up here. :-( Last edited by hemi43; 12-08-2017 at 06:15 PM. |
12-08-2017, 11:23 PM | #100 |
Carpe manana
Solid work. Thanks for updates. Strong work on the stripe - kanpai!
