Old 12-22-2017, 08:26 PM   #1
65truckowner
65truckowner's Avatar
64-66 chevy exhaust infront of tires
I am thinking about running my exhaust out infront of the rear tires. Anyone done this and I need pictures.
65truckowner is offline   Reply With Quote
Old 12-22-2017, 08:38 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: 64-66 chevy exhaust infront of tires
I used Camaro tips. Brockman Mellowtone mufflers
DPowers is offline   Reply With Quote
Old 12-22-2017, 09:12 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I had to run my exhaust to the outside of the frame, so I routed the downpipe under the rise in the front of the frame and did a turn out off of the muffler in front of the rear tire. Here are a couple of photos while I was fabricating the passenger side.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-22-2017, 09:39 PM   #4
Macdaddy1
Mine are also infront of the tires. no mufflers just straight pipes baby? Will try to send pics tomorrow.
Macdaddy1 is offline   Reply With Quote
Old 12-22-2017, 10:12 PM   #5
Backpayne
My exhaust is routed exactly like vin63's. It works very well this way and there is tons of room.
Backpayne is offline   Reply With Quote
Old 12-22-2017, 10:38 PM   #6
AcampoDave
AcampoDave's Avatar
I too did mine like Vin63 and it did sound good, but ultimately it proved to be too loud for long distance driving. I recently added tailpipes over the axle and straight down which was just enough to quiet it down to where I wanted.
But you know wnat they say, "if it's too loud your too old." I guess I am guilty as charged.
AcampoDave is offline   Reply With Quote
Old 12-25-2017, 10:33 PM   #7
racecougar
racecougar's Avatar
Very happy with this setup.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-26-2017, 10:00 PM   #8
65truckowner
Thanks for the pictures. The last truck is the same color as mine. As for being loud that will be fine with me. I am wanting a hot rod look and sound with this truck. Check out my build thread
Old 12-27-2017, 01:53 PM   #9
andyh1956
racecougar the stance on your truck is BadAss! With those tires & pipes hanging out the side of a SWB truck it looks like one of those Ed Roth Cartoons from the '60s!
Well Done!
andyh1956 is offline   Reply With Quote
Old 12-27-2017, 04:26 PM   #10
racecougar
racecougar's Avatar
Thanks!
Old 12-27-2017, 05:18 PM   #11
forestb
forestb's Avatar
mine but its a 62
forestb is offline   Reply With Quote
Old 12-27-2017, 08:33 PM   #12
65truckowner
Right on about the wide tires and stance. I really like the red one as well as the 62. There are not many of these trucks I dont like. Here is the one I am building now
Old 12-27-2017, 08:34 PM   #13
65truckowner
Old 12-27-2017, 08:37 PM   #14
65truckowner
Oh well I cant get the stupid picture to work. It is under 60-66 build title says rolled 65 project
Old 12-28-2017, 12:25 AM   #15
LVPhotos
LVPhotos's Avatar
Does this og pic count?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-31-2021, 01:02 AM   #16
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Anyone have sound issues having their exhaust routed this way?
I'm wanting to move my tank to the rear but I don't like how close the pipes would be to the tank.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-31-2021, 02:00 AM   #17
TJ's Chevy
TJ's Chevy's Avatar
I had the mufflers under the cab on my 66 and the resonation was horrible at 2000 rpm. Had no sound deadener but I don't think it would have helped much. Assuming you may not have enough room to put them behind the cab and still have the pipes route in front of the tires.
Old 05-31-2021, 09:36 AM   #18
AcampoDave
AcampoDave's Avatar
Yeah, It's louder for sure and if your a windows down kind of guy, you hear the sound of half your engine being deflected off of buildings and curbs. I still have a long bed with front of tire outlets on 2 inch pipe, but I personally dont care to hear much from my exhaust at all so I added resonators to my stock style mufflers which helps. On my shortbed I just got sick of it and lopped the pipes off under the cab and re-did the whole thing all the way out the back with 2.25" putting the mufflers under the bed and resonators fore and aft. The tailpipes and rearward resonators run right next to my rear mounted tank and I have run the truck very hard on very hot days and never found the tank too hot to touch.
Old 05-31-2021, 09:59 AM   #19
MT65
This isn’t in front of the tires, but when you go over the differential, you will be going to outside of your frame and most rear tanks are between the frame rails. I will finish with my outlets in back of the tires after getting over my soon to be built new differential...plenty of room between tank and exhaust
MT65 is offline   Reply With Quote
Old 05-31-2021, 02:52 PM   #20
AcampoDave
AcampoDave's Avatar
Here's a pic of how close mine are. You'll notice I had to rotate the resonators slightly off center to get a bit more breathing room. (Remember, the flanges on the tank sides stick out a good bit from the tank wall so at least the fuel itself is further in). Those rearward resonators were an afterthought so I was just happy they fit there at all.
Old 05-31-2021, 05:09 PM   #21
LostMy65
LostMy65's Avatar
Thanks guys.
Old 05-31-2021, 08:19 PM   #22
MT65
I made a mock-up and had my tank built locally, it fits between the rails so your resonators would be about 2-21/2 “ from the tank wall, I also will be turning the exhaust out behind the tire, I have a stainless roll pan , I don’t want anything below it. My tank is about 7” in the rear and slopes to 10” in the front
Old 05-31-2021, 09:11 PM   #23
1slo64
This is how I have mine set but I haven't ran the pipe yet.
1964 GMC Fleetside SWB
1966 Mustang Coupe
1slo64 is offline   Reply With Quote
