Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-27-2017, 07:03 PM   #1
ScottH
ScottH's Avatar
WTB Looking for frame bracket for z bar
Looking for the clutch bracket that sits on the frame which supports the z bar.
I believe it is riveted from the factory. A PO on the 65 I just picked up did a crappy job of welding one in the wrong position. Instead of fixing it correctly, they proceeded to cut a bigger hole in the floor so the pedal linkage would clear.
If anyone has one please post pics & price.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 12-27-2017, 09:47 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: WTB Looking for frame bracket for z bar
Almost positive I have on off a '65 that is still on the frame. Will be this weekend though before can check though.
DPowers is offline   Reply With Quote
Old 12-27-2017, 09:53 PM   #3
ScottH
ScottH's Avatar
No hurry on my end, wont b till spring b4 I can work on it.
Appreciate u checking.
Old 12-27-2017, 10:01 PM   #4
DPowers
DPowers's Avatar
Found a pic- This what you need correct?
Old 12-27-2017, 10:04 PM   #5
ScottH
ScottH's Avatar
yupper, the piece on the frame just above the shock.
BTW will u be cutting up the frame? Will also need a support bar that goes across the rear frame rails. Its the one the panhard bar bracket is right next to. I can post a pic tomorrow.
Old 12-27-2017, 10:11 PM   #6
DPowers
DPowers's Avatar
Yes I will. A guy is supposed to come get the bed this weekend.
Old 12-28-2017, 12:44 AM   #7
ScottH
ScottH's Avatar
The support I need is the 1 just after the rear in this pic (could also use the panhard bar diff mounting stud).
Hope that helps.
Old 12-28-2017, 08:59 AM   #8
DPowers
DPowers's Avatar
Just so I am clear, You mean this one?
Old 12-28-2017, 11:08 AM   #9
ScottH
ScottH's Avatar
yupper
Old 12-31-2017, 12:48 AM   #10
DPowers
DPowers's Avatar
Cut out the z bar bracket today. Will see about the other pieces on Monday. Also sent you a PM about patch piece you were asking about in other thread.
