![]() Join Date: Jan 2011
Re: What are my options here?
If you can find a donor piece from a dash that is close to the faded color of your dash you can make some fillers to correct the hole and then use a backing piece and panel bond to tie them in. There will be a small line but no welding. There are some rattle can paints that are close to light fawn but not exact. Your filler is dark fawn from a 66. You can spray it the light fawn and it will be closer then use extra fine scotchbrite to kill the shine and give it more of the look of your dash.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Tags |
dash, delete plate, interior, radio |
