Old 02-13-2018, 11:11 PM   #126
Black_Sheep
Black_Sheep's Avatar
Re: Brother's keeper - '58 Stepside build
I took a break from sanding and got some more done on the interior. Before reinstalling the newly modified brake pedal I finished installing the sound deadening on the cab floor and pieced together some 40oz jute carpet padding for the cab floor and toe board.
Black_Sheep is offline   Reply With Quote
Old 02-24-2018, 12:57 AM   #127
Black_Sheep
Waiting for paint to dry, I whipped up an aluminum mounting bracket for the tach. I think it looks much better than the stamped tin bracket that came with the gauge cup...
Old 02-24-2018, 09:22 AM   #128
Joe Pass
Joe Pass's Avatar
Nice....
Joe Pass is offline   Reply With Quote
Old 03-09-2018, 02:06 PM   #129
Black_Sheep
The custom tach I ordered from Speedhut showed up while we were on vacation so I got it wired up and installed. I need to find some small diameter loom before I can connect the wires.
Just before leaving I mocked up the stereo system and installed the antenna behind the seat. Reception is very good and the sound quality is better than expected.
Old 03-09-2018, 02:27 PM   #130
Black_Sheep
Wiring done, The green colored cover for the column and tach wiring will get painted gloss white to match the column.
Old 03-09-2018, 07:09 PM   #131
Joe Pass
Joe Pass's Avatar
Nice
Old 03-09-2018, 09:04 PM   #132
Dave0
Awesome work!
Dave0 is offline   Reply With Quote
Old 03-13-2018, 11:41 PM   #133
Black_Sheep
After sorting out the turn indicator wiring, the instrument cluster is in and functioning properly.
Old 03-14-2018, 01:10 PM   #134
Dan in Pasadena
Dan in Pasadena's Avatar
Looks REALLY good!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-14-2018, 01:54 PM   #135
Troy Sr
Troy Sr's Avatar
I love those green line gauges!! I used to have them in my '55 Belair!
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 03-14-2018, 02:29 PM   #136
ptc
ptc's Avatar
Looks really nice Mark, that two-tone dash came out just perfect and the gauges are totally fitting to it all.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-16-2018, 12:04 AM   #137
Black_Sheep
Doing the carpet now so I can have binding sewn on the edges. I was going to try to do it in one piece but now I'm leaning towards cutting a U shaped relief for the hump and make a second piece to cover the hump, slightly overlapping along the edge. There should be enough carpet left over to make some floor mats too.
Old 03-16-2018, 08:15 AM   #138
Joe Pass
Joe Pass's Avatar
That's going to look real nice
Old 03-16-2018, 09:04 AM   #139
oldman3
oldman3's Avatar
Looking good...Jim
oldman3 is offline   Reply With Quote
Old 03-17-2018, 05:53 PM   #140
Black_Sheep
Fed Ex called to set up a delivery for the bed sides I ordered from Mar-K. Since the terminal is only 15 minutes away, I picked them up this morning. Nice quality and very well packaged for shipping.
Anyway, my youngest was home so she helped me get the sides in place and held them until I could get a few bolts in. I installed the tail gate and got everything squared up, it went pretty easy. The rear sill didn't have holes for the license plat bracket so I got that done, the tail lights were installed to make sure all of the holes line up.
Old 03-17-2018, 06:06 PM   #141
Joe Pass
Joe Pass's Avatar
Nice... you decided not to go with your originals?.. I remember on the other forum when you radiused the ends...
Old 03-17-2018, 06:16 PM   #142
Black_Sheep
I know, all that work and I'm not going to use them. There was a lot of hidden issues discovered after I stripped the old paint and filler.
Old 03-24-2018, 01:30 PM   #143
Black_Sheep
Got the fuel tank vent done and finished fitting the carpeting. I even had enough left over to make a one piece front floor mat.
Old 03-24-2018, 06:30 PM   #144
Black_Sheep
Mocking up the steps and doing a little bodywork...
Old 03-24-2018, 06:56 PM   #145
Indian113
Indian113's Avatar
Man, that Carpet Looks Nice! It sure is goin to be a eye catcher when your Done
Indian113 is offline   Reply With Quote
Old 03-24-2018, 07:24 PM   #146
Joe Pass
Joe Pass's Avatar
Great work.....
Old 03-25-2018, 11:54 PM   #147
Black_Sheep
Last fender, SEM guide coat followed by block sanding revealed some low spots. Brand new rear fenders were far from perfect...
Old 03-31-2018, 03:02 PM   #148
Black_Sheep
After body working the rear fenders, I got them on for final mock up...
Old 03-31-2018, 05:48 PM   #149
Joe Pass
Joe Pass's Avatar
Looking good.....
Old 04-02-2018, 10:39 PM   #150
Black_Sheep
The last big hurdle is the doors. They are in great shape and won’t need much bodywork. I spent the evening removing an excessive amount of 3M yellow weatherstrip adhesive, finding and opening up drain holes and cleaning out a ridiculous amount of nuts, bolts, washers and general debris that was inside the doors...
