Old 03-15-2018, 08:24 PM   #1
GearCat
Doors won’t lock
Hey guys,
My doors appear to lock with the key from the outside, but when I go to open the door, the lock pops up and the door opens. I read another post stating maybe it is the latch?
I’ve sprayed a bunch of wd-40 in there with no luck. I’ve also locked the doors from the inside, gone around and opened the truck without the key.
You all have helped me get her running and I hope to be able to do some short trips around town soon.
Thanks in advance
GearCat is offline   Reply With Quote
Old 03-15-2018, 08:39 PM   #2
bigdog55
bigdog55's Avatar
Re: Doors won’t lock
our trucks only lock from the outside with the key. They won't lock any other way.
Brian
bigdog55 is offline   Reply With Quote
Old 03-15-2018, 08:51 PM   #3
chainsawman
chainsawman's Avatar
I have to push in on my doors to get them to lock all the way. Mine need a slight adjustment.
chainsawman is offline   Reply With Quote
Old 03-15-2018, 09:05 PM   #4
garyd1961
As stated above try pushing in on the door while you are turning the key.
garyd1961 is offline   Reply With Quote
Old 03-15-2018, 10:47 PM   #5
GearCat
Pushing the door in worked. This worked for the drivers side which has a newer door seal, but not for the passenger’s side door that is a little more sunken in without a new door seal.
Old 03-15-2018, 11:06 PM   #6
randy500
There is a link in my signature line explaining why your door wont latch unless pushed in....worn out latch is the problem. The write up offers a solution too....
randy500 is offline   Reply With Quote
