Old 06-27-2018, 12:58 AM   #1
ryanv70c10
70 Cab swap question
So I will be swaping cabs on my 70 and besides the cab bushings and bolts that fasten it to the frame is there anything else that I should have ahead of time? I know that there will be small things like bolts but I'm talking special order things that I can't get local.
While I'm at it, where are you all getting the bushings and bolts from?
TIA
ryanv70c10 is offline   Reply With Quote
Old 06-27-2018, 02:07 AM   #2
WhiteCST
WhiteCST's Avatar
Re: 70 Cab swap question
I’ll bump this, I’m about to do the same thing.
1953 Kaiser Manhattan “Sled”
1968 C10 CST LWB
1991 Trans Am GTA “White Nasty”
2006 Dodge Charger RT
Built TH400 for Sale
WhiteCST is offline   Reply With Quote
Old 06-27-2018, 10:06 PM   #3
ryanv70c10
bump.......
Old 06-28-2018, 12:59 PM   #4
cypressbog
Go Pack Go!
New cab mount kits can be purchased on-line from a variety of board supporting vendors.
cypressbog is offline   Reply With Quote
Old 06-28-2018, 02:49 PM   #5
ryanv70c10
Understood, I guess my question was what's the best brand to get I don't know if there's a bunch of different ones some may fit some may not fit. That's more what I was looking for guidance with.
Old 06-28-2018, 05:31 PM   #6
weq92f
weq92f's Avatar
If you're swapping the cab and going with new mounts, make sure to have some shims in case the cab needs a bit of help getting into position. Some of the new mounts can cause the cab to sit a bit lower. Get some big no rust washers at your local home store for this.
Avoid poly urethane bushing material.
The mount kits can be had online at the usual retailers as well as locally here on the board.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 06-28-2018, 06:41 PM   #7
randy500
There are a lot of cab mount kits and most are junk.
All of them have the wrong length spacers and its been that way for 20 plus years.
The good mount kits will have the rubber bonded to the metal on 1/2 ton kits for the upper bushings.
Keep track of your old bushings spacers and bolts and compare them to what you receive.
Correct the spacer length by finding new material, shortening the provided ones or using your old spacers.
Try to use your old bolts is they are not real rusty, they are rather special bolts and the ones in the kits are crappy hardware store stuff.
If you buy the kit from GMC Pauls you will be pretty happy. The kit I bought from him had incorrect spacers and hardware store bolts but it did have nice bushings.
Others sell similar kits to his but make sure you examine the pictures of what is offered before purchasing.
randy500 is offline   Reply With Quote
Old 06-28-2018, 07:01 PM   #8
Grumpy old man
Grumpy old man's Avatar
These work ,If your going to cab swap you may as well use new front core support mounts also .
https://www.classicparts.com/1967-72...info/35%2D145/
Old 06-30-2018, 02:07 AM   #9
ryanv70c10
Thank you guys you've been really helpful. Going to see if gmcpauls can get them to me quick otherwise I'll order the ones grumpy mentioned.
