Old 06-27-2018, 09:37 AM   #1
WB72
Before and After
WB72's Avatar
Mounting hard brake lines on axle
My brake line tabs have all broken or rusted off. What is the best way to kemp brake lines from moving?
I have seen plastic zip ties and metal hose clamps. Has anyone rebuilt factor looking tabs that weld back onto the axle?
I’m looking for the most secure way that doesn’t look like an afterthought or hillbilly repair.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 06-30-2018, 07:31 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Mounting hard brake lines on axle
Just saw this. If you have a welder friend, you can bend up some clips and he can tack them on. Just make sure that the tabs are shaped so that the lines don't get crushed when you hammer the tabs over. It doesn't take much to hold the line from rattling.
~Steven
Simi Valley, CA
