06-27-2018, 07:36 PM | #1 |
Power Steering 68 gmc 4x4
I have the pump and the power steering box , what else do I need to change over from manual to PS on my 68 gmc 4x4
06-29-2018, 11:03 AM | #2 |
Go Pack Go!
Re: Power Steering 68 gmc 4x4
You might want to get in touch with Mike (67-72chevytrucks). He’s in Marquette, MI and completes 100 point concours restorations on these trucks. He has a 1968 short fleet 4x4 50th anniversary truck. He’s been looking for the ram assist power steering components for a 4x4 for several years now.
06-29-2018, 11:37 AM | #3 |
[QUOTE=cypressbog;8291165]You might want to get in touch with Mike (67-72chevytrucks). He’s in Marquette, MI and completes 100 point concours restorations on these trucks. He has a 1968 short fleet 4x4 50th anniversary truck. He’s been looking for the ram assist power steering components for a 4x4 for several years now.[/QUOT
Thank you but I need more info to get ahold of him |
06-29-2018, 02:58 PM | #4 |
Welcome to the board
And in Michigan too not to far from dowagiac Things you my need Pittman arm Mounting bracket Hoses And not sure if the tierod is the same for manual and power Have fun |
06-29-2018, 03:09 PM | #5 |
This is a piece of cake to do. Steering box (4wd only), steering pump, brackets for steering pump, pulleys for steering pump. hoses between box and pump, small clip that holds hoses to frame, pitman arm, fluid for pump, belt for pump. Done!!
06-29-2018, 04:47 PM | #6 |
Go Pack Go!
[/QUOT
Thank you but I need more info to get ahold of him[/QUOTE] His birth name is mike, his board name is 67-72chevytrucks. Search the members list for his contact info. |
06-29-2018, 07:28 PM | #7 |
I've never owned a '68 (yes to '67)
It seems some '68's didn't have the accommodation dimples to take a integrated power box. Take a close up pic of your mounted manual box. If it doesn't have the dimples some people add a spacer or even modify the frame. Otherwise you're looking for something that wasn't even listed as an option
06-30-2018, 08:21 AM | #8 | |
06-30-2018, 08:37 AM | #9 |
Does some one sell the plate your adding for the PS box?
06-30-2018, 08:40 AM | #10 | |
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
06-30-2018, 10:57 AM | #11 | |
1968 introduced the intregrated PS box and it is fatter. So the frame horn is different in this area. I don't remember seeing power steering being available on 4x4 in '68. Best just to look your frame to see if the box will fit. If it is flat then Captfab makes an adapter bracket.
06-30-2018, 11:52 AM | #12 |
Go Pack Go!
Yes power steering was available in 1968. If I remember correct, the 4x4 used ram assist with the dimple in the frame.
06-30-2018, 11:52 AM | #13 | |
06-30-2018, 12:00 PM | #14 |
06-30-2018, 12:23 PM | #15 |
Ok ,here’s what I have.
06-30-2018, 12:25 PM | #16 |
A couple more
07-01-2018, 01:37 AM | #17 |
All about them K’s
The dimples space the box off of the frame. Without them The area circled in green will hit the frame before the mounting ears on the box are tight against the frame.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 07-01-2018 at 01:44 AM. |
07-01-2018, 07:20 AM | #18 |
Than this has to be changed too , where do you get one ? I looked at LMC ,they don’t offer them?
I know this isn’t rocket science but I have contacted several outfits. Like lmc, brothers, eklers , cardid . no one seems to know about this and what I need but I knew someone on this board would have answers. I can find one but it’s for a lifted truck and has only 3 hole to mount , mine has 4 ? Some one point me in the right direction . Last edited by mygmctruck1; 07-01-2018 at 07:47 AM. |
07-01-2018, 08:03 AM | #19 |
Closed knuckle steering arm. Maybe with the right combinations of tie rod ends you can make a drag link of the correct length.
07-01-2018, 08:37 AM | #20 |
Good morning
I am not familiar with your gear box in pictures It is not the normal Saginaw box I think most are referring to Do you know what it originally came off of As far as the steering arm and tie rod you circled those should work With a Saginaw box and pitman arm (see pic) |
07-01-2018, 05:26 PM | #21 | |
