![]() Join Date: Feb 2012
"Goo on bottom of hei modual ?
New to hei. What's this about "goo on bottom of hei modual ?" And would that also go for the petronix modual that replaces points ? I don't remember anything about this in installation instructions. Wonder if the "goo" is present on new distributors ?
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! Last edited by panhead59; 07-07-2018 at 08:13 PM. |
![]() Join Date: Jan 2001
Re: "Goo on bottom of hei modual ?
HEI uses thermal compound like computer CPUs do to transfer heat. Your module won't last long without it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Widely available at local auto parts stores ? What's it called ? Thermal compound ?
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom) 1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK. 1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive ! |
Who Changed This?
![]() Join Date: Jan 2013
It's a conductive grease. The really good stuff uses silver particles, and the price shows it. That's for some really high heat transfer. An HEI module doesn't run as hot as an overclocked CPU, so doesn't need that good a conductivity.
So the petronix modual in my goat probably needs the goo. A modual is a modual right ? They are basically doing the same function.
#6 | |
The modules the various Pertronix systems use inside the distributor are simply an electronic trigger. The module in the HEI does more than just act as a trigger, thus it gets hot while the Pertonix modules don't really get hot on their own.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
For my HEI distributors I buy thermal compound (also called thermal paste) at Best Buy or a computer store. It's a little more expensive, but a tube lasts a long time.
Ok tks guys. You can learn something new on here everyday ! I bet i wasn't the only one that didn't know about the grease. Not talked about a lot.
It's die-electric grease.
It helps dissipate the heat generated by the module and conducts electricity(ground)New modules usually come with a note saying to use it. Same stuff used to mount the cooling fins in your computer and for the same reason. The better auto parts stores have it-Just ask for die-electric grease. You do need to use it! Mike. ![]() |
#10 | |
Thermal compound will transfer heat. It won't insulate it. |
Part nunber SL203 at Autozone
